Resistor Ohm Meter
Results 1 to 40 of 43
    Italy
    Seems a bit of a waste to have one LM334 for each range though.
    Hi Trent,
    The price of a LM334 is USD 1.20.
    If you have just one LM334 you will have to switch the resistors and this
    will reduce the accuracy of the measurement system. Just supply the +5V
    to each LM334 with an I/O of the microcontroller and you are done. The
    transistor BC547 is not needed because the I/O of a PIC can supply more
    than 10mA.
    Best regards,
    Luciano
    T.Jackson's Avatar
    T.Jackson Guest
    Bet I could work something for a quarter of the cost with the help of a 4066 quad bi-lateral switch. The LM334 is around $2.50 in Australia.
    Oct 2007
    Hi All
    Way back I seem to remember seeing a circuit in some book or other that acts like a resistor but can be changed using only electronic means. Was supposed to replace the volume pot in a amplifier I think.
    Question 1 : Is it possible to "emulate" a resistor in this way?
    Question 2 : Is it possible to "emulate" a capacitor as well?
    Now the big question : If both the above are possible, does anyone have a circuit for each that is nice and simple (and stable).
    Reason: I still like the 555 timer idea but dont want to have a whole bunch if resistors and caps to get it working. If there is a way to "create" the values I need, lets get the PIC to do the hard work. I'll worry about the display later.
    Best
    Aubrey
    (The more you learn, the more you realise how little you actually know)
    T.Jackson's Avatar
    T.Jackson Guest
    Emulating a resistor? - grab yourself a BJT (bipolar junction transistor) - and there's your emulator. As for a capacitor? - just find other parts that exhibit good quantities of capacitive like characteristics and model a circuit around them.
    Arrow Tera ohm meter
    hello friends,
    I already obtain the range of 1mohm to 1 tera ohm but i need to go upto 1000 teraohm as per my specification.
    so I need Schematic for this solution.
    Thanking you,
    khetani krunal
    Dec 2007
    Finland
    Post Wow!
    Second time Wow!!
    Your application must be something really extreme or not!
    1000 Tera = 1000 * 10^12 = 1 Peta
    So, you really want to measure up to 1 Peta ohm and with some self-made equipment
    Before any hints for schematics. Could you tell a little bit more about you application?
    Sorry, but this question make me smile
    BR,
    -Gusse-
    I am also interested in the test voltage used for measuring the resistor?
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 21:42
  2. VU Meter
    By Andre_Pretorius in forum General
    Last Post: - 20th May 2009, 17:17
  3. Help...Distance Meter
    By tohu thomson in forum General
    Last Post: - 18th September 2007, 08:07
  4. frequency meter in PBP
    Last Post: - 13th June 2007, 07:34
  5. PIC10F206 - What is the LOWEST Power @ Rest or Sleep
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 15:42
