Resistor Ohm Meter
Results 1 to 40 of 43
    Dec 2007
    Finland
    Post Wow!
    Second time Wow!!
    Your application must be something really extreme or not!
    1000 Tera = 1000 * 10^12 = 1 Peta
    So, you really want to measure up to 1 Peta ohm and with some self-made equipment
    Before any hints for schematics. Could you tell a little bit more about you application?
    Sorry, but this question make me smile
    BR,
    -Gusse-
    I am also interested in the test voltage used for measuring the resistor?
    Arrow resistance measurement
    hello,
    These type of measuring devices are used to mesure Transformer oil conductivity.You will find other site too.
    Once again i am asking for the schematic related to this topic.
    thanking you,
    krunal khetani
    Dec 2007
    Finland
    Post
    I would be also very curious to know that, because it must be very high. Also how low currents you can measure? Depends on that quite much.
    Quote Originally Posted by khetanikrunal View Post
    hello,
    thanking you,
    krunal khetani
    I though that it must be something to do with insulators, obviously. Is there any way that you could boost your existing equipment? I know, 1000x times more is pretty tough requirement (=1000x times high test voltage).
    BR,
    -Gusse-
    Arrow Rx mesurement
    see My test voltage is 500 V DC...
    Even i must use amplification of lower current(from Piko amp to Nenoamp)..
    system is like this
    HV(500v dc)----->Resistance of Oil(1mohm to 2000Tera Ohm)------>LV.
    And i have to Take current from LV point and convert it to voltage send to controller via ADC.
    Dec 2007
    Finland
    Post ADC limiting factor
    So your current sense capability is limited to ~0.5nA with 1Tera ohm measurement equipment. Definetely it would be much easier to try lower sensing capability than increase test voltage.
    Most sensible would be increase test voltage by 2x (or 4x) and try to improve current sensing (what ever it might need).
    Pico amper range current sensing is very demanding and any noise from environment will affect your results (even measuring at DC). Most probably you have to do your measurements in shielded rooms, etc..
    Even if you could build up measurement system that could measure up to 2 Peta ohm then limiting factor for accuracy would be ADC (even 16bit). One step would be ~30.5G ohm. Probably you should consider some better ADC than in PICs. (This is valid only if you have just one range for input, full range).
    BR,
    -Gusse-
    Arrow Adc
    hello
    I can measure up to 3 nenoamp and 6 uV.
    event thats not problem.
    I am not able to get linearity.
    i.e., if ADC o/p 500mV for 1 teraohm.
    then i am not getting 250 mV for 2teraohm.
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 21:42
  2. VU Meter
    By Andre_Pretorius in forum General
    Last Post: - 20th May 2009, 17:17
  3. Help...Distance Meter
    By tohu thomson in forum General
    Last Post: - 18th September 2007, 08:07
  4. frequency meter in PBP
    Last Post: - 13th June 2007, 07:34
  5. PIC10F206 - What is the LOWEST Power @ Rest or Sleep
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 15:42
