Permanent sleep
Results 1 to 40 of 59
Thread: Permanent sleep
    Apr 2006
    New Hampshire USA
    Smile How about this
    Those who really followed this thread have surely noticed there could have been other lines inserted between :
    @ SLEEP
    @ nop
    AND ...
    Blink:
    didn't you ??? ....
    Hello Alain,
    Do you mean:
    @ SLEEP
    @ nop
    snore
    Blink:
    turn-over
    @ SLEEP
    Then again, sometimes I "just don’t quite get it"...
    -Adam-
    Gotta get new glasses.
    @nap
    Did not work
    Wink
    <body onload="setInterval('blinkIt()',1000)">
    <script type="text/javascript">
    function blinkIt() {
    if (!document.all) return;
    else {
    for(i=0;i<document.all.tags('blink').length;i++){
    s=document.all.tags('blink')[i];
    s.style.visibility=(s.style.visibility=='visible') ?'hidden':'visible';
    </script>
    <blink>@ NOP</blink>
    @nap will just define a label
    nap without the @, is a PBP function, and it's not the same as ASM
    Sep 2003
    INDIA
    A half hearted compile of your code (Alian) for the 16F873A gave an error with DEFINE INTHAND _Blink.
    I changed it to DEFINE INTHAND Blink and it did not come out of sleep (I presume) the same code compiles OK for the 16F628A.
    I am sorry , I was busy with some other job, but today I shall try your code for the intended chip and post results.
    Thank you for all your help,
    regards
    Talking Rtfm !!!
    Hi, Charudatt
    See chapter 9.3 ...
    your device ( 16F873 ) has two mem. pages ... 16F628 only has ONE.
    What does PbP for ASM Interrupts ???
    What do you have to reserve as variables room ???
    TWO beers now !!!
    Cheers
    T.Jackson's Avatar
    T.Jackson Guest
    else {
    </script>
    C'mon Mister_e, you can do better than that! - show us all some of your "real" java skills, like scrolling some 3D text with user definable parameters.
    euh... sorry i don't have any Java skills... i just copy/paste some script here and there.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    I'm about to start a Java unit soon - maybe I'll teach you a thing or two Out of interest, I've just found some good code for VB that allows serial comms without MSCOMM.ocx !!! http://www.thescarms.com/VBasic/commio.aspx No probs in XP either.
    it's just too bad that it doesn't allow to open COM port > 15 or 16
    Talking
    Quote Originally Posted by Pic_User View Post
    Hello Alain,
    Do you mean:
    @ SLEEP
    @ nop
    snore
    Blink:
    turn-over
    @ SLEEP
    -Adam-
    Hi, Adam
    Snore never happens ... might be a LABEL to call before !!!
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Using Sleep
    Last Post: - 17th August 2008, 04:05
  4. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  5. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
