Permanent sleep
Results 1 to 40 of 59
Thread: Permanent sleep
    Wink The last ?
    Hi, RON
    Ok, Thanks for the explanation ...
    It really might be written instead of BUT ... : AND any interrupt ... !!!
    So, appears no real need to set the GIE bit here ...
    Back to Charudatt's program ...
    mighn't there be a PORTB reading ... ( to end the "mismatch condition" ) ???.
    Charudatt :
    1) DEFINE ...INIT ... the result is quite normal !!! Pic wakes up to fall asleep ...
    2) if the led keeps blinking means ... the program always stay in the interrupt stubb !!! We've traced it now.
    in this case ... interrupt flags are not cleared ... : good reason, no ?
    Talking Finally GOT it !!!
    Hi, Charudatt
    Straight from my test bench :
    @ __CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _LVP_OFF & _PWRTE_OFF & _CP_OFF & _BODEN_OFF
    DEFINE NO_CLRWDT 1
    DEFINE LCD_EBIT 1
    CMCON=7
    VRCON=%01101100 'VRCON bit7 is OFF for no current drain
    OPTION_REG.7 = 1 ' DISABLE INTERNAL PULLUPS
    Porta = 0
    PORTB = 0
    Trisa = %11111111
    Trisb = %01111111
    LED VAR PORTB.5
    SleepLed var PORTB.7
    Dummy var byte
    ' PIC Low-Power Sleep Routine
    ' Set Sleep Interrupts
    INTCON=%00010000 ' Interrupt Control Register
    ' 7=0 - GIE - Global Interrupt Enable
    ' 6=0 - PEIE - Peripheral Interrupt Enable
    ' 5=0 - TOIE - TMR0 Overflow Interrupt Enable
    ' 4=1 - INTE - RB0/INT Enable
    ' 3=0 - RBIE - PORTB change interrupt Enable
    ' 2=0 - TOIF - TMR0 Overflow Flag
    ' 1-0 - INTF - RB0/Ext Interrupt Flag
    ' 0=0 - RBIF - PORTB Interrupt Flag
    OPTION_REG.6=1 ' 1=RB0 Rising-Edge Trigger, 0=Falling-Edge Trigger
    PAUSE 500
    LCDOUT $FE,1
    CYCLE:
    ' Reset Interrupt Flags
    INTCON.1=0 ' Reset RB0 Flag
    INTCON.0=0 ' Reset PORTB change Flag
    ' Sleep
    LOW LED
    LCDOUT $FE,2 , "*** SLEEPING ***"
    High Sleepled
    @ SLEEP
    Dummy = PORTB
    LOW SleepLed
    @ nop
    @ nop
    @ nop
    Pause 100 ' Needed for system Wake-Up
    HIGH LED : PAUSE 200
    LCDOUT $FE,1, " HURRY UP "
    PAUSE 5000
    LOW LED
    GOTO CYCLE
    CONFIG Modified to suit MPLAB Requirements ...
    I used a LCD to show what happening and fixed LEDs for Wake (green) /Sleep ( Red ) states ...
    disabled CLRWDT PbP insertions ... ( a passing idea ??? )
    also disabled the WPU ... but that is not problematic.
    also changed LEDs PORTs ...
    As PORTB was used ... I did not try "Interrupt change on PortB" ... but works great with B.0 interrupt.
    Works fine ... as you intended to program it !!!
    Sep 2003
    INDIA
    Default Thanks
    I'll give it a shot tomorrow and post my feedback.
    regards
    p.s. Today after the failed experiments, i am planning the same thing on 16F73. Lets hope it works. I shall post my feedback on both tomorrow.
    Wink A Beer aside for me ...
    Hi, Charudatt
    DEFINE NO_CLRWDT 1
    CMCON=7
    OPTION_REG.7 = 0 ' ENABLE INTERNAL PULLUPS
    Porta = 0
    PORTB = %11110001
    Trisa = %11110011
    Trisb = %01111111
    LED VAR PORTA.2
    SleepLed var PORTA.3
    Dummy var byte
    INTCON=%00011000 ' Interrupt Control Register
    ' 3=1 - RBIE - PORTB change interrupt Enable
    OPTION_REG.6=0 ' 1=RB0 Rising-Edge Trigger, 0=Falling-Edge Trigger
    CYCLE:
    ' Sleep
    LOW LED
    High Sleepled
    @ SLEEP
    @ nop
    Dummy = PORTB
    LOW SleepLed
    @ nop
    @ nop
    @ nop
    HIGH LED
    While ( PORTB >> 4 ) <> %00001111 ' Wait Key release
    Wend ' AND a PORTB Reading ...!!!
    PAUSE 200
    PAUSE 5000
    LOW LED
    GOTO CYCLE
    Here it is with PORTB interrupts ... ( Note I modified all inputs to be active LOW ...)
    I think the origin of the problem is you forgot to read PORTB for the end of the mismatch condition ... wich Also locks the flag cancelling ( a RTFDatasheet for me ... )
    Heuuuuu, CHILLED, the beer, please !!!
    PS : The interrupt way also works well ... if you're intersted in, I'll post it.
    The original program example I posted way back during another life is valid for the non-A version of the 16F62X. In the non-A version you get a wake from sleep regardless of the state of the GIE bit. However, the operation of the GIE bit differs in the A version in that respect and Alain is correct. It teaches us all a lesson here that some of the changes between PIC versions are seriously subtle! So it's read the Datasheet - thoroughly!
    Not another RTFD?!?!
    Sep 2003
    INDIA
    Default Cheers for Beer.
    PS : The interrupt way also works well ... if you're intersted in, I'll post it.[/QUOTE]
    Thank you very much, I am just dying to test it out.
    Yes Chilled beer for sure.
    Post the Interrupt way code, if you can, Thank you once again.
    regards
    Sep 2003
    Vermont
    Hey Mel,
    I read the data sheet on the A version. It says on page 111 that the PIC will wake from sleep if both the flag and interrupt bits are set. Will it not wake from sleep if the flag bit is set after initiating sleep? I don't see where it discusses this.
    Ron
    I'm talking about the GIE bit here. In the A version, if GIE is not set, the SLEEP (the Assembler instruction) is treated as a NOP and the PIC never enters SLEEP. This didn't work that way in the non-A version. I've a (fortunately) obsolete product that used that feature... otherwise I'd be scratching my head trying to figure why the product didn't work as expected!
    Post The interrupt Way
    Hi, Charudatt
    Here it is :
    DEFINE NO_CLRWDT 1
    DEFINE INTHAND _Blink
    CMCON=7
    Porta = 0
    PORTB = %11110001
    Trisa = %11110011
    Trisb = %11111111
    LED VAR PORTA.2
    Dummy var byte
    INTCON=%10011000 ' Interrupt Control Register
    OPTION_REG.6 = 0 ' 1=RB0 Rising-Edge Trigger, 0=Falling-Edge Trigger
    CYCLE:
    INTCON.1 = 0 ' Reset RB0 Flag
    INTCON.0 = 0 ' Reset PORTB change Flag
    INTCON.7 = 1
    ' Sleep
    LOW LED
    High Sleepled
    @ SLEEP
    @ nop
    Blink:
    Dummy = PORTB
    LOW SleepLed
    HIGH LED
    Wend
    PAUSE 200
    PAUSE 5000
    LOW LED
    GOTO CYCLE
    As you see it's not so different from the "non interrupted" way ...
    But, IF I correctly understand Mel ( one more time, Mel : You're the one and Only ... !!! - no sexual meanings hidden ( LOL) ) , the interrupt way could fit both 628 and 628A ...
    I must say I used a 16F628-04 batch N° 0145H9F for tests ( I do not have any 628A ... but will run a try with a brand new 648A.
    A little "bug" in the "non interrupted" listing ... to correct:
    TRISB must be % 11111111 ... instead of % 01111111
    I was wondering why PortB.7 was inactive .... LOL !!!
    Have fun, and read you soon
    regards
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Using Sleep
    Last Post: - 17th August 2008, 04:05
  4. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  5. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
