Permanent sleep
Results 1 to 40 of 59
Thread: Permanent sleep
    Post The interrupt Way
    Hi, Charudatt
    Here it is :
    @ __CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _LVP_OFF & _PWRTE_OFF & _CP_OFF & _BODEN_OFF
    DEFINE NO_CLRWDT 1
    DEFINE INTHAND _Blink
    CMCON=7
    VRCON=%01101100 'VRCON bit7 is OFF for no current drain
    OPTION_REG.7 = 0 ' ENABLE INTERNAL PULLUPS
    Porta = 0
    PORTB = %11110001
    Trisa = %11110011
    Trisb = %11111111
    LED VAR PORTA.2
    SleepLed var PORTA.3
    Dummy var byte
    ' PIC Low-Power Sleep Routine
    ' Set Sleep Interrupts
    INTCON=%10011000 ' Interrupt Control Register
    ' 7=0 - GIE - Global Interrupt Enable
    ' 6=0 - PEIE - Peripheral Interrupt Enable
    ' 5=0 - TOIE - TMR0 Overflow Interrupt Enable
    ' 4=1 - INTE - RB0/INT Enable
    ' 3=1 - RBIE - PORTB change interrupt Enable
    ' 2=0 - TOIF - TMR0 Overflow Flag
    ' 1-0 - INTF - RB0/Ext Interrupt Flag
    ' 0=0 - RBIF - PORTB Interrupt Flag
    OPTION_REG.6 = 0 ' 1=RB0 Rising-Edge Trigger, 0=Falling-Edge Trigger
    CYCLE:
    ' Reset Interrupt Flags
    INTCON.1 = 0 ' Reset RB0 Flag
    INTCON.0 = 0 ' Reset PORTB change Flag
    INTCON.7 = 1
    ' Sleep
    LOW LED
    High Sleepled
    @ SLEEP
    @ nop
    Blink:
    Dummy = PORTB
    Pause 100 ' Needed for system Wake-Up
    LOW SleepLed
    HIGH LED
    While ( PORTB >> 4 ) <> %00001111
    Wend
    PAUSE 200
    PAUSE 5000
    LOW LED
    GOTO CYCLE
    As you see it's not so different from the "non interrupted" way ...
    But, IF I correctly understand Mel ( one more time, Mel : You're the one and Only ... !!! - no sexual meanings hidden ( LOL) ) , the interrupt way could fit both 628 and 628A ...
    I must say I used a 16F628-04 batch N° 0145H9F for tests ( I do not have any 628A ... but will run a try with a brand new 648A.
    A little "bug" in the "non interrupted" listing ... to correct:
    TRISB must be % 11111111 ... instead of % 01111111
    I was wondering why PortB.7 was inactive .... LOL !!!
    Have fun, and read you soon
    regards
    Talking Humour ...
    Those who really followed this thread have surely noticed there could have been other lines inserted between :
    @ SLEEP
    @ nop
    AND ...
    Blink:
    didn't you ??? ....
    Apr 2006
    New Hampshire USA
    Smile How about this
    @ SLEEP
    @ nop
    AND ...
    Blink:
    didn't you ??? ....
    Hello Alain,
    Do you mean:
    @ SLEEP
    @ nop
    snore
    Blink:
    turn-over
    @ SLEEP
    Then again, sometimes I "just don’t quite get it"...
    -Adam-
    Gotta get new glasses.
    @nap
    Did not work
    Wink
    <body onload="setInterval('blinkIt()',1000)">
    <script type="text/javascript">
    function blinkIt() {
    if (!document.all) return;
    else {
    for(i=0;i<document.all.tags('blink').length;i++){
    s=document.all.tags('blink')[i];
    s.style.visibility=(s.style.visibility=='visible') ?'hidden':'visible';
    </script>
    <blink>@ NOP</blink>
    @nap will just define a label
    nap without the @, is a PBP function, and it's not the same as ASM
    Sep 2003
    INDIA
    A half hearted compile of your code (Alian) for the 16F873A gave an error with DEFINE INTHAND _Blink.
    I changed it to DEFINE INTHAND Blink and it did not come out of sleep (I presume) the same code compiles OK for the 16F628A.
    I am sorry , I was busy with some other job, but today I shall try your code for the intended chip and post results.
    Thank you for all your help,
    regards
    Talking Rtfm !!!
    Hi, Charudatt
    See chapter 9.3 ...
    your device ( 16F873 ) has two mem. pages ... 16F628 only has ONE.
    What does PbP for ASM Interrupts ???
    What do you have to reserve as variables room ???
    TWO beers now !!!
    Cheers
    T.Jackson's Avatar
    T.Jackson Guest
    else {
    </script>
    C'mon Mister_e, you can do better than that! - show us all some of your "real" java skills, like scrolling some 3D text with user definable parameters.
    euh... sorry i don't have any Java skills... i just copy/paste some script here and there.
    Talking
    Quote Originally Posted by Pic_User View Post
    Hello Alain,
    Do you mean:
    @ SLEEP
    @ nop
    snore
    Blink:
    turn-over
    @ SLEEP
    -Adam-
    Hi, Adam
    Snore never happens ... might be a LABEL to call before !!!
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Using Sleep
    Last Post: - 17th August 2008, 04:05
  4. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  5. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
