Problem with led
Results 1 to 16 of 16
    Quote Originally Posted by savnik View Post
    I test now and it's work (thanks to skimask) , but when i press the 0 turn off both leds.
    I want if i press one time the 1 to turn the led1 on and if i press again the 1 to turn off the led1.The same for the led2
    Have you tried the toggle command?
    Jun 2006
    No.
    I try now with toggle and work.
    Thank you.
    I add this:
    if new = 1 then toggle led1
    if new = 2 then toggle led2
    The only problem now is :
    when power up for the first time , i must press the number 2 > enter and again the number 2 > enter to turn the led on (only for number 2 - not for number 1)
    After this no need second time to press the number 2.
    No.
    Thank you.
    I add this:
    Have you no imagination? No creative thoughts?
    CMCON = 7
    ANSEL = 0
    adcon.1 = 7
    new var byte
    led1 var PORTA.2
    led2 var PORTA.3
    new = 0
    serout porta.0, T9600, ["Enter which LED to light (1-2,0=Off): ", 10, 13]
    serin porta.1, T9600, new
    serout porta.0, T9600, ["LED Chosen: ", new, 10, 13]
    if new = "1" then
    if led1 = 1 then
    led1 = 0
    led1 = 1
    if new = "2" then
    if led2 = 1 then
    led2 = 0
    led2 = 1
    if new = "0" then
    low led1 : low led2
    Default Set the value . .
    No.
    Thank you.
    I add this:
    Hi Savnik,
    in your code do this, put your code into nice little chunks that you can see what they do. Chunk1 put all your defines and variable declarations.
    chunk 2 is start directory. chunk 3 is main loop. this will help you stay organised.In the start subdirectory give your variables a set value,
    I think this should help.
    CMCON = 7
    ANSEL = 0
    adcon.1 = 7
    new var byte
    led1 var PORTA.2
    led2 var PORTA.3
    Start:
    led1 = 0
    led2 = 0
    new = 0
    serout porta.0, T9600, ["Enter which LED to light ", 10, 13]
    if new = "1" then
    if led1 = 1 then
    led1 = 0
    led1 = 1
    if new = "2" then
    if led2 = 1 then
    led2 = 0
    led2 = 1
    if new = "0" then
    low led1 : low led2
    The commands in the start directory will run only once at startup and should set both leds in the off condition.
    Hi Savnik,
    CMCON = 7
    ANSEL = 0
    adcon.1 = 7
    new var byte
    led1 var PORTA.2
    led2 var PORTA.3
    Start:
    led1 = 0
    led2 = 0
    new = 0
    if new = "1" then
    if led1 = 1 then
    led1 = 0
    led1 = 1
    if new = "2" then
    if led2 = 1 then
    led2 = 0
    led2 = 1
    if new = "0" then
    low led1 : low led2
    Now why didn't I think of that
    Jun 2006
    Default now work
    thanks skimask and Joe S.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. LCD will not start
  5. Flashing!! LED Dot matrix problem
    Last Post: - 4th December 2006, 09:45
