transmitter:
043
receiver:
578 C 892 F
plus the counters
How about this... (getting annoying isn't it?)
I commented out the encoding/decoding parts. Just sending a split up raw value now....see what happens...
'RECEIVE PIC
'same includes and defines as the other versions
temp var word : tempf var word : counter var byte : templo var byte
temphi var byte : input portb.2 : converts var byte[15] : convtemp var byte
converts[0] = $55 : converts[1] = $56 : converts[2] = $59
converts[3] = $5a : converts[4] = $65 : converts[5] = $66
converts[6] = $69 : converts[7] = $6a : converts[8] = $95
converts[9] = $96 : converts[10] = $99 : converts[11] = $9a
converts[12] = $a5 : converts[13] = $a6 : converts[14] = $a9
converts[15] = $aa : pause 1000
loop:
counter = counter + 1 : lcdout $fe , $c0 , "Waiting......" , DEC3 counter
waitfor55:
serin portb.2 , n2400 , temp : if temp <> $55 then goto waitfor55
waitforaa:
serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
serin portb.2 , n2400 , templo : serin portb.2 , n2400 , temphi
'for convtemp = 0 to 15
'if templo = converts[temp] then templo = convtemp
'if temphi = converts[temp] then temphi = convtemp
'next convtemp
temp = ( temphi << 4 ) + templo : tempf = temp * 9 : tempf = tempf / 5
tempf = tempf + 32
lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "F."
lcdout $fe , $c0 , "Received....." , DEC3 count
goto loop
'TRANSMIT PIC
'remove the char_pacing value, with it in there, the RX will lose it's "training"
counter var byte : temp var word : output portb.2 : high portb.2
input portb.3 : dq var portb.4 : templo var byte : temphi var byte
converts var byte[15] : converts[0] = $55 : converts[1] = $56
converts[2] = $59 : converts[3] = $5a : converts[4] = $65
converts[5] = $66 : converts[6] = $69 : converts[7] = $6a
converts[8] = $95 : converts[9] = $96 : converts[10] = $99
converts[11] = $9a : converts[12] = $a5 : converts[13] = $a6
converts[14] = $a9 : converts[15] = $aa : pause 1000
loop:
lcdout $fe , $c0 , "Getting......" , DEC3 count : owout DQ , 1 , [ $cc ]
owout DQ , 0 , [ $44 ] : Pause 500 : owout DQ , 1 , [ $cc ]
owout DQ , 0 , [ $be ]
owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
lcdout $fe , $c0 , "Sending......" , DEC3 count
templo = temp.lowbyte & $f : temphi = temp.lowbyte >> 4
'templo = converts[templo] : temphi = converts[temphi]
serout portb.2 , n2400 , [ $55 , $55 , $55 , $55 , $aa ]
serout portb.2 , n2400 , [ templo , temphi ]
goto loop
ok eee, seems to be working now, am I awake....
thank you thank you
i will try the wireless
what is this line for (was for , or intended to)
