Serin serout problem
Results 1 to 40 of 337
    [QUOTE=lerameur;30072]the code I have is the code you have on top a couple of posts ago, I am trying to add multiple items to it though
    I'm modifying it a bit (adding the manchester encoding stuff) so you can hook up the wireless modules and try it with one byte. Should be easier to add more data after the wireless it working with byte, then to make sure multiple bytes work without the wireless....that's my thought anyways...
    Sep 2006
    you can look at the first post I have manchester encoding there and it works
    Quote Originally Posted by lerameur View Post
    It probably does work, but I threw this together....unless I made some silly mistakes, this should work with (and without) the wireless modules, in fact it should work just fine with the wire still attached. Maybe it wouldn't be a bad idea to test it out that way also...
    'RECEIVE PIC
    'same includes and defines as the other versions
    temp var word : tempf var word : counter var byte
    templo var byte : temphi var byte : input portb.2
    converts var byte[15] : convtemp var byte
    converts[0]=$55 : converts[1]=$56 : converts[2]=$59 : converts[3]=$5a
    converts[4]=$65 : converts[5]=$66 : converts[6]=$69 : converts[7]=$6a
    converts[8]=$95 : converts[9]=$96 : converts[10]=$99 : converts[11]=$9a
    converts[12]=$a5 : converts[13]=$a6 : converts[14]=$a9 : converts[15]=$aa
    loop:
    counter = counter + 1 : lcdout $fe , $c0 , "Waiting......" , DEC3 counter
    waitfor55:
    serin portb.2 , t2400 , temp : if temp <> $55 then goto waitfor55
    waitforaa:
    serin portb.2 , t2400 , temp : if temp <> $aa then goto waitforaa
    serin portb.2 , t2400 , templo : serin portb.2 , t2400 , temphi
    for convtemp = 0 to 15
    if templo = converts[temp] then temp1 = convtemp
    if temphi = converts[temp] then temp2 = convtemp
    next convtemp
    temp = ( temp2 * 16 ) + temp1
    tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "F."
    lcdout $fe , $c0 , "Received....." , DEC3 count
    goto loop
    'TRANSMIT PIC
    'can probably reduce the char_pacing value quite a bit now that it's working
    counter var byte : temp var word : output portb.2 : high portb.2
    input portb.3 : dq var portb.4 : templo var byte : temphi var byte
    loop:
    lcdout $fe , $c0 , "Getting......" , DEC3 count
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $44 ] : Pause 500
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $be ]
    owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
    lcdout $fe , $c0 , "Sending......" , DEC3 count
    templo = temp.lowbyte & $f : temphi = temp.lowbyte >> 4
    templo = converts[templo] : temphi = converts[temphi]
    serout portb.2 , t2400 , [ $55 , $55 , $55 , $55 , $aa ]
    serout portb.2 , t2400 , [ templo ] : serout portb.2 , t2400 , [ temphi ]
    goto loop
    Sep 2006
    what are temp1 and temp2 used for in the receiving code ?
    because it is used at the end of the program , but the value is not initialized to anything, , no input,
    Whoops....should be hi and lo instead of 1 and 2
    temp = ( temphi * 16 ) + templo
    Sep 2006
    This is one way of encoding I have not seen before,
    you did not like the loop I was doing in the first post ?
    It displays 578C and 872F on the receiver side,
    I will look at the decodin technique, because I do not know if it is encoding error or calculation error.
    Is this with the wireless or with the wires like before? Could be either type of error.... I'll look at it a bit more....
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
