SERIN doesn't use brackets!!!!!!
SEROUT DOES use brackets!!!!!!
(My installation of Acrobat reader's fonts got screwed up at my end sometime in the past, that's what been messing it up. With the brackets in place, serin has been waiting for qualifiers this whole time, not actual data!)
'RECEIVE PIC
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
temp var word : tempf var word
leader var byte : trailer var byte : count var byte
temp1 var byte : temp2 var byte : temp3 var byte : temp4 var byte
input portb.2 : pause 1000
loop:
lcdout $fe , $c0 , "Waiting......" , DEC3 count
temp = 0 : tempf = 0
leader = 0 : trailer = 0 : count = 0
temp1 = 0 : temp2 = 0 : temp3 = 0 : temp4 = 0
serin portb.2 , t2400 , leader 'get leader byte
serin portb.2 , t2400 , temp1
serin portb.2 , t2400 , temp2
serin portb.2 , t2400 , temp3
serin portb.2 , t2400 , temp4
serin portb.2 , t2400 , count
serin portb.2 , t2400 , trailer
if ( leader + trailer ) <> $ff then 'if leader + trailer doesn't add up right...
lcdout $fe , $c0 , "Out of Sync..", DEC3 count : goto loop
temp.highbyte = temp1
temp.lowbyte = temp2
tempf.highbyte = temp3
tempf.lowbyte = temp4
lcdout $fe , $c0 , "Received....." , DEC3 count
lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "F."
goto loop
'TRANSMIT PIC
DEFINE CHAR_PACING 33333
count var byte
output portb.2 : high portb.2 : input portb.3 : dq var portb.4
pause 1500
loop:
lcdout $fe , $c0 , "Getting......" , DEC3 count
owout DQ , 1 , [ $cc ]
owout DQ , 0 , [ $44 ]
Pause 500
owout DQ , 0 , [ $be ]
owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
lcdout $fe , $c0 , "Display......" , DEC3 count
lcdout $fe , $c0 , "Sending......" , DEC3 count
serout portb.2, t2400 , [ $aa ] 'send a leader byte
temp1 = temp.highbyte : temp2 = temp.lowbyte
serout portb.2 , t2400 , [ temp1 ]
serout portb.2 , t2400 , [ temp2 ] 'send data
temp3 = tempf.highbyte : temp4 = tempf.lowbyte
serout portb.2 , t2400 , [ temp3 ]
serout portb.2 , t2400 , [ temp4 ] 'send data
serout portb.2 , t2400 , [ count ] 'send count
serout portb.2 , t2400 , [ $ff ] 'send a trailer byte
lcdout $fe , $c0 , "Sent....." , DEC3 try1 , "," , DEC3 try2
count = count + 1
goto loop
And that should do it!!!
