Serin serout problem
Results 1 to 40 of 337
    Default And yet again...
    'RECEIVE PIC
    'same includes and defines as the other versions
    temp var word : tempf var word : counter var byte : templo var byte : temphi var byte : input portb.2 : converts var byte[15]
    convtemp var byte : converts[0] = $55 : converts[1] = $56 : converts[2] = $59 : converts[3] = $5a : converts[4] = $65
    converts[5] = $66 : converts[6] = $69 : converts[7] = $6a : converts[8] = $95 : converts[9] = $96 : converts[10] = $99
    converts[11] = $9a : converts[12] = $a5 : converts[13] = $a6 : converts[14] = $a9 : converts[15] = $aa
    loop:
    counter = counter + 1 : lcdout $fe , $c0 , "Waiting......" , DEC3 counter
    waitfor55:
    serin portb.2 , t2400 , temp : if temp <> $55 then goto waitfor55
    waitforaa:
    serin portb.2 , t2400 , temp : if temp <> $aa then goto waitforaa
    serin portb.2 , t2400 , templo : serin portb.2 , t2400 , temphi
    for convtemp = 0 to 15
    if templo = converts[temp] then templo = convtemp
    if temphi = converts[temp] then temphi = convtemp
    next convtemp
    temp = ( temphi << 4 ) + templo : tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "F." : lcdout $fe , $c0 , "Received....." , DEC3 count
    goto loop
    'TRANSMIT PIC
    'same includes and defines as the other versions, EXCEPT --------------
    'change the char_pacing value to 500. If it's a large value (above 1000 or so), the receiver loses it's "training"
    counter var byte : temp var word : output portb.2 : high portb.2 : input portb.3 : dq var portb.4 : templo var byte
    temphi var byte :converts var byte[15] : converts[0]=$55 : converts[1]=$56 : converts[2]=$59 : converts[3]=$5a
    converts[4]=$65 : converts[5]=$66 : converts[6]=$69 : converts[7]=$6a : converts[8]=$95 : converts[9]=$96 : converts[10]=$99
    converts[11]=$9a : converts[12]=$a5 : converts[13]=$a6 : converts[14]=$a9 : converts[15]=$aa : pause 1000
    loop:
    lcdout $fe , $c0 , "Getting......" , DEC3 count : owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $44 ] : Pause 500
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $be ] : owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
    lcdout $fe , $80 , "Tc=" , DEC3 temp : lcdout $fe , $c0 , "Sending......" , DEC3 count
    templo = temp.lowbyte & $f : temphi = temp.lowbyte >> 4 : templo = converts[templo] : temphi = converts[temphi]
    serout portb.2 , t2400 , [ $55 , $55 , $55 , $55 , $aa , templo , temphi ]
    goto loop
    Sep 2006
    still getting extremely high values at the receiving end:
    578C 872F
    Quote Originally Posted by lerameur View Post
    578C 872F
    Good numbers at the transmitter side?
    Sep 2006
    yes , the transmitter is good
    Well, what are the numbers at the TX and RX side?
    Sep 2006
    transmitter:
    043
    receiver:
    578 C 892 F
    plus the counters
    transmitter:
    043
    receiver:
    578 C 892 F
    plus the counters
    Try n2400 instead of t2400.
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
