LCD serial backpacks
Results 1 to 40 of 68
Threaded View
  1. #8
    Smile Ok Here it is
    Ok enough of my whining, here is some workable code, thanks to Darrel Taylor, well mostly about 99 percent. He wrote it for something else, I added a monkey wrench and a screwdriver and it works for my needs, could it be better? Well you can judge for your self, it works good enough for my application as is
    Thanks Once again Darrel for the post I extracated this code from.
    @ DEVICE pic16F628A, HS_OSC
    @ DEVICE pic16F628A, WDT_OFF
    ' Watchdog Timer
    @ DEVICE pic16F628A, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F628A, MCLR_ON
    ' Master Clear Options (Internal)
    @ DEVICE pic16F628A, BOD_OFF
    ' Brown-Out Detect
    @ DEVICE pic16F628A, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F628A, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    ' Set to CPD_ON for Release Copy
    @ DEVICE pic16F628A, PROTECT_OFF
    ' Program Code Protection
    ' Set to PROTECT_OFF for Development Copy
    ' Set to PROTECT_ON for Release Copy
    trisb = %00000010
    trisA = %11110011
    include "modedefs.bas"
    Define  LCD_DREG        PORTB
    Define  LCD_DBIT        4
    Define  LCD_RSREG       PORTA
    Define  LCD_RSBIT       0
    Define  LCD_EREG        PORTA
    Define  LCD_EBIT        1
    DEFINE LCD_LINES 4             'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000     'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 50         'Define delay time between data sent.
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h        ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 20h        ' Enable transmit, BRGH = 0
    DEFINE HSER_SPBRG 32         ' FOR 20MHZ 129 = 2400, 32=9600,25 @ 4 for 2400
    DEFINE HSER_CLROERR 1        ' Clear overflow automatically
            RCIF VAR PIR1.5      ' Receive  interrupt flag (1=full , 0=empty)
            TXIF VAR PIR1.4      ' Transmit interrupt flag (1=empty, 0=full)
    LED VAR PORTA.4
    OERR    VAR    RCSTA.1             ' Alias OERR (USART Overrun Error Flag)
    CREN    VAR    RCSTA.4             ' Alias CREN (USART Continuous Receive Enable)
    buffer_size    CON    64             ' Sets the size of the ring buffer, set up from 32
    buffer    VAR    BYTE[buffer_size]' Array variable for holding received characters
    index_in    VAR    BYTE          ' Pointer - next empty location in buffer
    index_out    VAR    BYTE         ' Pointer - location of oldest character in buffer
    bufchar    VAR    BYTE             ' Stores the character retrieved from the buffer
    i        VAR    BYTE             ' loop counter
    Col        VAR    BYTE             ' Stores location on LCD for text wrapping
    errflag    VAR    BYTE             ' Holds error flags
    index_in = 0
    index_out = 0
    i = 0
    col = 1
                                    'RxData var byte
            CMCON = 7               ' PORTA is digital
            Pause 100               ' Wait for LCD to startup
            high PortA.2            ' power for backlight
            low  PortA.3            ' backlight ground
    INTCON = %11000000                ' Enable interrupts
    ON INTERRUPT GoTo serialin        ' Declare interrupt handler routine
    PIE1.5 = 1                        ' Enable interrupt on USART
    pause 1500
    lcdout $FE,1
    lcdout $FE,2
    LCDOUT "Your Text Goes Here"
    PAUSE 2000
    ' * * * * * * * * * * * * *   Main program starts here - blink an LED at 1Hz
    ' I removed some code here, it seems to require what's left
    loop:
            For i = 0 to 10     ' Delay for .02 seconds (10*2mS)
                Pause 2           ' Use a short pause within a loop
            Next i                ' instead of one long pause
    display:                          ' dump the buffer to the LCD
            IF errflag Then error    ' Handle error if needed
            IF index_in = index_out Then loop    ' loop if nothing in buffer
            GoSub getbuf            ' Get a character from buffer
            LCDOut bufchar            ' Send the character to LCD
            IF col > 20 Then        ' Check for end of line
                col = 1                ' Reset LCD location
                LCDOut $fe,$c0,REP " "\20    ' Clear line-2 of LCD
                LCDOut $FE,2        ' Tell LCD to return home
            EndIF
    GoTo display            ' Check for more characters in buffer
                            ' Subroutines
    Disable                    ' Don't check for interrupts in this section
    getbuf:                    ' move the next character in buffer to bufchar
        index_out = (index_out + 1)            ' Increment index_out pointer (0 to 63)
                                            ' Reset pointer if outside of buffer
        IF index_out > (buffer_size-1) Then index_out = 0
        bufchar = buffer[index_out]            ' Read buffer location
    error:                              ' Display error message if buffer has overrun
        IF errflag.1 Then              ' Determine the error
            LCDOut $FE,$c0,"Clearing Display    Buffer"    ' Display buffer error on
                                                        ' line-2 and 3 Buff overrun
        Else
            LCDOut $FE,$D4,"USART Overrun"    ' Display usart error on line-4
        EndIF
        LCDOut $fe,2                    ' Send the LCD cursor back to line-1 home
        For i = 2 to col                ' Loop for each column beyond 1
            LCDOut $fe,$14                ' Move the cursor right to the right column
        Next i                          ' $14 = 20 DEC.
        errflag = 0            ' Reset the error flag
        CREN = 0            ' Disable continuous receive to clear overrun flag
        CREN = 1            ' Enable continuous receive
        GoTo display        ' Errors cleared, time to work.
    ' * * * * * * * * * * * * * * *  Interrupt handler
    serialin:                        ' Buffer the character received
        IF OERR Then usart_error    ' Check for USART errors
        index_in = (index_in + 1)    ' Increment index_in pointer (0 to 63)
        IF index_in > (buffer_size-1) Then index_in = 0    'Reset pointer if outside of buffer
        IF index_in = index_out Then buffer_error    ' Check for buffer overrun
        HSerin [buffer[index_in]]    ' Read USART and store character to next empty location
        IF RCIF Then serialin        ' Check for another character while we're here
    Resume                            ' Return to program
    buffer_error:
        errflag.1 = 1        ' Set the error flag for software
    ' Move pointer back to avoid corrupting the buffer. MIN insures that it ends up within the buffer.
        index_in = (index_in - 1) MIN (buffer_size - 1)
        HSerin [buffer[index_in]]    ' Overwrite the last character stored (resets the interrupt flag)
    usart_error:
        errflag.0 = 1        ' Set the error flag for hardware
    As I gain coding experience I will revisit this code unless someone else does so first ;-)
    JS
    Oh, what I really like about this is you use the standard formatting commands as used with LCDOUT, no funky commands.
  1. 16f688 LCD what have I done wrong
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 02:48
  3. Play with LCD on PICDEM
  4. Serial LCD
    Last Post: - 15th November 2007, 08:31
  5. Need help with LCD number display.
