LCD serial backpacks
Results 1 to 40 of 68
    Aug 2009
    Default Thanks.
    Thank you sir.
    Aug 2009
    Well, after I read a group of posts I started to understand what your interest of introducing these new interrupts was. I am not very familiar with interrupts but I want to take advantage of this new approach. First I did was to try to play with your Blink program and at compilation time (16F628) I got an error: “Variable wsave3 position request 416 beyond Ram_End 335” I have look every where for an explanation of this error with no luck. Please, advice.
    There is a section in the DT_INTS-14.bas file that has to be adjusted for the chip you are compiling for.
    I wish I could make it automatic, but there's no way to do that.
    For a 16F628, it doesn't have any General Purpose RAM in BANK3. So you have to comment out the wsave3 variable in this section.
    wsave       var byte    $20     SYSTEM      ' location for W if in bank0
    ;wsave       var byte    $70     SYSTEM     ' alternate save location for W
                                                ' if using $70, comment out wsave1-3
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    ;wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    The 628 also has Access RAM at address $70 which can be accessed from any bank.
    So commenting everything and uncommenting the $70 variable will work too.
    Either way will work ... take your pick.
    ;wsave       var byte    $20     SYSTEM      ' location for W if in bank0
    ;wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    Aug 2009
    I'll report to you. Thanks
    Aug 2009
    Well, beautiful. I comment out the 3 wsaves and everything came out as planned. I tested the 628 on my breadboard and the led blinked as expected. After that triumph I load your Serialin (I called Parallel to Serial) program and compiled it. I got one error only
    “Error [118] C:\program~1\mecanic~1\mcs\parallel~3 asm 200:Overwriting previous address contents(2007)” As always I try to find that error on the posts and I did but I don’t understand how to fix it. Thanks.
    Quote Originally Posted by timseven View Post
    I think you've found just about every possible problem.
    With the following advice from mister_e, I'm sure you'll reach the finish line.
    http://www.picbasic.co.uk/forum/show...=6775#post6775
    Aug 2009
    I got it!!! It complied perfectly and now comes the hardware test. I’ll do the setup and let you know how it worked. I think the worse part is over. I thank you and indirectly to Melanie, Steve and many others that post their problems and solution in this forum. I want to learn all about these unique interrupts from the bottom up. I’ll be around here for some time. TimSeven
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Serial LCD
    Last Post: - 15th November 2007, 09:31
  5. Need help with LCD number display.
