10F222 no response?
Results 1 to 9 of 9
    Default Re: 10F222 no response?
    Oooops, my fault ... wrong chip selected
    this one looks to work fine...
    '   set parameters
    ADCON0=0 'all digital I/O
    TRISIO=0 'all outputs (GPIO.3 is input only so it's ignored)
    DEFINE OSC 8
    DEFINE OSCCAL_1K 1
    '     variables and constants
    tempvar var byte
    '    Other housekeeping
    'peekcode $1FF, tempvar 'OSCCAL calibration value
    'POKE $05, tempvar      'OSCCAL register location
    '     begin program
    GPIO.0=0
    loophere:
    GPIO.0=1
    GPIO.0=0
    goto loophere
    But you should use PEEKCODE along with POKECODE ... but POKECODE needs a CONSTANT to be stored !
    Quote Originally Posted by Acetronics2 View Post
    '   set parameters
    DEFINE OSC 8
    DEFINE OSCCAL_1K 1
    tempvar var byte
    '     begin program
    GPIO.0=0
    loophere:
    GPIO.0=1
    GPIO.0=0
    goto loophere
    I'm not writing to CODE area though, it's writing to the OSCCAL register, location $05. Am I wrong in thinking this should do it? It didn't recognize OSCCAL and threw an error when I tried writing it to the register directly using that naming convention.
    As far as I know OSCCAL the thing is only for calibrating/adjusting/tweaking the actual oscillator frequency so that it's within specification. It should not be needed to get the chip running and I don't think it relates to your problem.
    OSCCAL = tempvar
    Or perhaps even
    PEEKCODE $1FF, OSCCAL
    Should do it. But again, I'd remove it from the code until you get a blinky running.
    OSCCAL = tempvar
    Or perhaps even
    Thanks - it's setting OSCCON that's the issue apparently. If I don't bother, it works fine. Anything else, nope. It does NOT like OSCCAL being mentioned. The PEEKCODE $1FF, OSCCAL compiles, but has the same "he's dead, Jim" result.
    However, having said that, Acetronics2 used "DEFINE OSCCAL_1K 1", which I can only assume grabs the value for OSCCON from the last code address on a 1K pic and uses it in a snippet of code to drop the value into its rightful register. In this case, it would wrap-around while reading from $3FF (the referenced 1k mark) since there's only 512bytes, but it should still result in the same thing happening.
    Thanks guys, for the input - blinky is blinking and I'm away to the races. I would NOT have thought that a poke to the OSCCAL would lock things up, regardless of the value written to it, and the fact that it's not recognized as a register is a head-scratcher.
  1. 10F222 wake/sleep
    By AvionicsMaster1 in forum PBP3
    Last Post: - 23rd August 2013, 09:03
  2. 10F222 ADRES as one more VAR?
    By JetPack Spartan in forum mel PIC BASIC Pro
    Last Post: - 10th May 2010, 15:54
  3. Error programming 10F222
    By JoelMurphy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 16:23
  4. 10F222 ADC Problem
    Last Post: - 30th October 2008, 04:46
  5. 10f222
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 31st October 2006, 18:09
