You are compiling for the correct chip, 10F222?
Not sure at this point but I had a look through my code folder I found one piece of code for the 10F222. It's likely something I wrote in response to a question on the forum:Looking at the code now, 8 years down the road, I see a forgot to DEFINE OSC 8 which might explain the comment towards the end. That same comment, however, seems to indicate it WAS tested on an actual hardware.Code:'**************************************************************** '* Name : Frequency Generator.pbp * '* Author : Henrik Olsson * '* Notice : Copyright (c) 2017 Henrik Olsson * '* : All Rights Reserved * '* Date : 2017-03-07 * '* Version : 1.0 * '* Notes : For 10F222. * '* : * '**************************************************************** #CONFIG __config _IOFSCS_8MHZ & _WDT_OFF & _MCLRE_OFF & _CP_OFF #ENDCONFIG DEFINE NO_CLRWDT 1 ' Forces manual use of CLRWDT GPIO = %0000 TRISIO = %00111101 ADCON0 = %01000001 ' GPIO 0 = Analog, ADC Enabled SPK VAR GPIO.1 Trigger VAR GPIO.2 GO_DONE VAR ADCON0.1 SomeValue CON 75 SomeConstant CON 12 Main: IF Trigger THEN GO_DONE = 1 SPK = 1 ' Set pin high WHILE GO_DONE : WEND ' AD conversion will always take the same amount of time PAUSEUS SomeValue + (ADRES * SomeConstant) GO_DONE = 1 SPK = 0 ' Set pin low WHILE GO_DONE : WEND ' AD conversion will always take the same amount of time PAUSEUS 16 + SomeValue + (ADRES * SomeConstant) ' The 16 above is to make the dutycycle closer to 50% than what it was ' without it. I'm quite surprised such a high number was needed and I'm ' not sure why that is. ENDIF Goto Main
