10F222 no response?
Results 1 to 9 of 9
    Default Re: 10F222 no response?
    Since there is no #CONFIG in your code I reccon you know that the default ones are what you want? I don't have access to those at the moment but what about MCLR? Is it enabled in the default CONFIG and if so, do you have it pulled up?
    Also, looking at the datasheet there is no mention of TRISIO, it seems to be called TRISGPIO in that device. It's possible that the PBP header files aliases it and I suppose you should get an error if it doesn't know TRISIO but still...it sticks out.
    Thanks for your reply!
    Yup, I have MCLR set as MCLR, and also have the pullup option set AND have a 10k pullup externally. Name:  10F222 config.jpg
    I tried using TRISGPIO first and it threw an error so I changed it to TRISIO and THEN it compiled without errors, so that's where I currently am.
    This has me stymied. I have tried another chip just in case, and I get the same results.
    You are compiling for the correct chip, 10F222?
    Not sure at this point but I had a look through my code folder I found one piece of code for the 10F222. It's likely something I wrote in response to a question on the forum:
    '*  Name    : Frequency Generator.pbp                           *
    '*  Author  : Henrik Olsson                                     *
    '*  Notice  : Copyright (c) 2017 Henrik Olsson                  *
    '*  Date    : 2017-03-07                                        *
    '*  Notes   : For 10F222.                                       *
       __config _IOFSCS_8MHZ & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE NO_CLRWDT 1             ' Forces manual use of CLRWDT
    GPIO = %0000
    TRISIO = %00111101
    ADCON0   = %01000001	       ' GPIO 0 = Analog, ADC Enabled
    SPK VAR GPIO.1
    Trigger VAR GPIO.2
    GO_DONE  VAR  ADCON0.1
    SomeValue CON 75
    SomeConstant CON 12
    IF Trigger THEN
      GO_DONE = 1
      SPK = 1                ' Set pin high
      WHILE GO_DONE : WEND   ' AD conversion will always take the same amount of time
      PAUSEUS SomeValue + (ADRES * SomeConstant)
      GO_DONE = 1
      SPK = 0                ' Set pin low
      PAUSEUS 16 + SomeValue + (ADRES * SomeConstant)
      ' The 16 above is to make the dutycycle closer to 50% than what it was
      ' without it. I'm quite surprised such a high number was needed and I'm
      ' not sure why that is.
    Goto Main
    Looking at the code now, 8 years down the road, I see a forgot to DEFINE OSC 8 which might explain the comment towards the end. That same comment, however, seems to indicate it WAS tested on an actual hardware.
  1. 10F222 wake/sleep
    By AvionicsMaster1 in forum PBP3
    Last Post: - 23rd August 2013, 08:03
  2. 10F222 ADRES as one more VAR?
    By JetPack Spartan in forum mel PIC BASIC Pro
    Last Post: - 10th May 2010, 14:54
  3. Error programming 10F222
    By JoelMurphy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 15:23
  4. 10F222 ADC Problem
    Last Post: - 30th October 2008, 03:46
  5. 10f222
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 31st October 2006, 17:09
