How to adjust values to a new range
Results 1 to 27 of 27
    Default Re: How to adjust values to a new range
    As I turn the pot, the formula should convert from 0 all the way to 1023, to a new range of 100 to 235
    OutputValue = 100 + (InputValue */ 34)
    Many ways to skin a cat but Henriks is the best!
    Fast and simple!
    That's awesome Henrik. It works like a charm.
    Can you explain how you got 34? It's not jumping out at me.
    "A simple way to think about '*/' is that it shifts the result 8 places to the right,
    resulting in an automatic division by 256.
    I'm just not sure how you went about figuring that out.
    I'd like to convert 34 into a formula for future use when I have to use a different range (cause I'm sure to have that need - several Flight Sim variables use pots and have their own range of values).
  1. Simple way to adjust interrupt speed in DT_INTS-14 ?
    Last Post: - 8th January 2015, 13:01
  2. Use a pot to adjust COUNT value
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 20th November 2011, 16:56
  3. Select Case range of values
    By kenif in forum PBP Wish List
    Last Post: - 25th June 2009, 14:27
  4. Replies: 9
    Last Post: - 31st July 2008, 09:56
  5. If Then Range
    Last Post: - 29th June 2005, 15:33
