How to adjust values to a new range
Results 1 to 27 of 27
    Default Re: How to adjust values to a new range
    Or maybe use a formula
    X=135*256/1023
    where X is the number you wan to use in the */
    135 is the max scale value
    1023 is the max ADC value
    error posting
    not to beat this up too much........
    A horse is never too dead on the web.
    ... if you only need 135 output values, and you want to scale pot for 0 to 100%..... just use the top 8 bit from a/d and this trend line function that excel gave.
    I can't believe I was playing with excel all that time and never thought of using the chart feature.
    My ADC is only 10 bits, not 16.
    So I just divide 10bits by 4 to reduce from 1023 down to 255, then slap it through your formula.
    I haven't done any math yet (just thinking, while I work on my encoder logic), but this probably equates to what Ioannis is suggesting.
    deleted because I realized the formula excel created was not correct...... me bad
    ok, so the a/d has setting to shift bits so you can take the high byte only as the MSB, same as /4 ...... then the formula is (53 X reading)/100 + 100................ for ....0 to 255=100 to 235
  1. Simple way to adjust interrupt speed in DT_INTS-14 ?
    Last Post: - 8th January 2015, 13:01
  2. Use a pot to adjust COUNT value
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 20th November 2011, 16:56
  3. Select Case range of values
    By kenif in forum PBP Wish List
    Last Post: - 25th June 2009, 14:27
  4. Replies: 9
    Last Post: - 31st July 2008, 09:56
  5. If Then Range
    Last Post: - 29th June 2005, 15:33
