How to adjust values to a new range
Results 1 to 27 of 27
    Question How to adjust values to a new range
    I have 10-bit ADC reading with a usable range of 400 - 930.
    How can I adjust that value to create a range of 100 to 230?
    I've been dividing the ADC by 4 to get a PWM of 0 to 255, but all PWM values below 100 are useless, and values above 235 will shorten the life of a LCD.
    I'm at my wits end after 2 days.
    Default Re: How to adjust values to a new range
    pbp has a max and a min commands
    by combining max and min you can constrain a variable to a
    range of values
    But that will still leave a dead space at the beginning and end of the pot. I need to convert on the fly a value from 400-900 to 100-235.
    There has to be a formula to do this. I never got far in algebra in school. I don't even know what to use as a search string in google.
    Bombay, India
    The concept of mapping a range should be clear by this code example in C explained
    // map a value(inputlow to inputhigh) to the range(outputlow to outputhigh)
    int16   map(int16 val, int16 inpl, int16 inph, int16 outl, int16 outh){
    int32 tmp=MAX(val,inpl)-inpl;                         // tmp = (maximum of Val and inputlow) - inputlow
        tmp *= (outh-outl);                                      // tmp = tmp * (outputhigh - outputlow)
        tmp /= (inph-inpl);                                       // tmp = tmp / (inputhigh - inputlow)
        tmp += outl;                                                // tmp = tmp + outputlow
        return MIN(tmp,outh);                                 // return the lower of tmp or outputhigh
    I just realized I didn't express myself properly.
    As I turn the pot, the formula should convert from 0 all the way to 1023, to a new range of 100 to 235.
    Or else I have that dead spot under 400 and above 900.
    ... tmp = (maximum of Val and inputlow) - inputlow...
    I'm puzzled by what is Maximum of Val? Is that the actual ADC input?
    EDIT: Oh, I get it, it's the maximum value between the input (ADC in) and InputLow (400).
    Freaking awesome!
    Name:  Range formula.png
    Aaaaaaaannnd I'm screwed.
    I go over 65,025 and I'm barely 1/2 to 1023 ADC input, that puts me over the WORD limit. I looked at the compiler options in MCSP and it says PBPL is for 18F only, I'm using a 16F1937 for this project.
    I don't know what my options are at this point...
    EDIT: Hmmm, what if I divide my input by 4, and adjust my input range accordingly...
    EDIT SOME MORE: WOOOT! It works freaking awesome! Thanks Jerson!
  1. Simple way to adjust interrupt speed in DT_INTS-14 ?
    Last Post: - 8th January 2015, 12:01
  2. Use a pot to adjust COUNT value
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 20th November 2011, 15:56
  3. Select Case range of values
    By kenif in forum PBP Wish List
    Last Post: - 25th June 2009, 13:27
  4. Replies: 9
    Last Post: - 31st July 2008, 08:56
  5. If Then Range
    Last Post: - 29th June 2005, 14:33
