Stuck on first attempt using MPLAB X (PICkit4)
+ Reply to Thread
Results 1 to 40 of 40
    Default Re: Stuck on first attempt using MPLAB X
    Its free for you!
    Its free for you!
    Nope, $50. Or am I missing out on "special promotion to forum moderators"?
    https://store.melabs.com/cat/PBPUP.html
    Well, there is no moderator offer.
    Did you try to down load and install the later version and then auto activate it?
    I do not really remember when was my upgrade that I had to pay. Then on, I just updated the compiler and it auto activated.
    I was missing a pull-up on MCLR, and my soldering job was dodgey. I made a new harness, looks much nicer.
    Still going nowhere in MCS+5; keep seeing HEX FILE MISSING before the command line window closes.
    Managed to program using MPLAB IPE, I just don't get any blinky action on my Lab X-1.
    Connecting to MPLAB PICkit 4
    Currently loaded versions:
    Application version...........00.08.54
    Boot version..................01.00.00
    Script version................00.05.35
    Script build number...........86fedc5c2e
    Tool pack version ............1.13.1519
    PICkit 4 is supplying power to the target (5.00 volts).
    Target device PIC16F877 found.
    Device Revision Id = 0x6
    Device Id = 0x9a0
    2023-04-04 19:42:56 -0400 - Programming...
    Calculating memory ranges for operation...
    Erasing...
    The following memory area(s) will be programmed:
    program memory: start address = 0x0, end address = 0x39
    configuration memory
    Programming/Verify complete
    2023-04-04 19:42:59 -0400 - Programming complete
    *** Release From Reset mode is enabled ***
    I'm gonna set up a breadboard, got a feeling something is wonky on my Lab-X1 (either OSC setting, jumpers, or that programmer header.
    Aug 2011
    Get rid of the config DEBUG_ON.
    If you ever get to the point of hdw debugging that will be managed by the tool for you.
    Also, when you were creating the IDE custom programmer entry, once you get to the step of setting the parameters there is no "Next" step... just "Finish"
    Thanks, had already turned it off. Waiting for a reply from MeLabs forum to get the custom programmer working in MCS+5.
    Kept playing with the Lab X-1 and MPLAB IPE, played with OSC, added PORT, used bits like I did in one of my programs; now the proper LED comes on, but no blinking on the Lab X-1.
        __config _HS_OSC & _WDT_OFF & _WRT_OFF & _BODEN_ON & _LVP_OFF  & _CPD_OFF & _PWRTE_OFF & _DEBUG_OFF
    DEFINE  OSC     20
    ADCON1 = 7              ' A/D off, all digital
    PORTD = %00000000
    TRISD = %00000000
    START:  PORTD = %00000001
            PAUSE   500
            PORTD = %00000000
            GOTO    START
    Finish: end
    Tried using another PIC just in case, no difference.
    But get this, I copied an old example of writing to the LCD and that worked, a bit wonky, but I can't get a solitary LED to blink.
    You won't see a 1uS blink
    START:  PORTD = 000001
            PAUSE   500
            PORTD = 000000
            GOTO    START
    you probably meant
            PAUSE   500
            PORTD = 000000
            PAUSE   500
            GOTO    START
  1. Replies: 19
    Last Post: - 16th May 2023, 18:06
  2. My serial to parallel attempt
    By johndoug in forum mel PIC BASIC Pro
    Last Post: - 4th January 2013, 05:15
  3. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 02:15
  4. MPLAB Quickbuild stuck on
    By RichardBowser in forum mel PIC BASIC Pro
    Last Post: - 9th July 2006, 03:52
  5. First attempt at coding
    By bartman in forum mel PIC BASIC
    Last Post: - 10th November 2004, 18:52
Members who have read this thread : 11
