Too many threads about the same topic.Waiting for a reply from MeLabs forum to get the custom programmer working in MCS+5.
I just set up MPLABX 5.35, MCSP5, and installed the PICKit4 as a custom programmer.
The only thing I changed was the commandline parameters(TPPK4=use generic tool PK4 instead of 'BUR serial no', W3.3=power target from PK4 @ 3.3V)Code:-TPPK4 -P$target-device$ -F$hex-filename$ -W3.3 -E -M -Y -OL -OB
Those changes shouldn't matter much.
Here's the output from the commandline window
When you select 'Program' in MCSP, the command window opens and it takes a good 10 seconds before anything happens. That's just the way it it with ipecmd and MPLABX.Code:***************************************************** Connecting to MPLAB PICkit 4... Currently loaded versions: Application version............00.09.46 Boot version...................01.00.00 Script version.................00.05.58 Script build number............abbfe90327 Tool pack version .............1.15.1688 PICkit 4 is supplying power to the target (3.26 volts). Target device PIC18F26K22 found. Device Revision Id = 0x4 ***************************************************** Erasing... Erase successful ***************************************************** Calculating memory ranges for operation... Erasing... The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x7f configuration memory Programming/Verify complete Program Report 05-Apr-2023, 07:07:36 Device Type:PIC18F26K22 Program Succeeded. PK4 Verify Report 05-Apr-2023, 07:07:36 Device Type:PIC18F26K22 ***************************************************** The following memory area(s) will be verified: program memory: start address = 0x0, end address = 0xffff configuration memory EEData memory User Id Memory Verification successful. Verify Succeeded. Batch Mode Count : 1
If you've installed multiple versions of MPLABX, make sure you use the matching versions of ipecmd.exe and MPLABX IPE to test it with.
Also, when you setup the custom programmer entry in MCSP I'd use the "find manually" option for setting the path, which for me was
"D:\Programs\Microchip\MPLABX\v5.35\mplab_platform\ mplab_ipe" since I use custom installs. Be sure to test it using the IPE first... that way you know everythings working.
