Stuck on first attempt using MPLAB X (PICkit4)
+ Reply to Thread
Results 1 to 40 of 40
    Default Re: Stuck on first attempt using MPLAB X
    Might as well check if I can use PICKIT4 with that...
    i use mplabx 5.50 with my pk4 , i use mplabx_ipe to pgm with, there probably is a cmdline version that
    mcs could use but i cannot be bothered fussing with that junk any longer
    Ok, so my dream of using PBP3, MPLAB X and PICKIT4 are not extinguished ... yet.
    I must be missing some setting in MPLAB X, or a file somewhere...
    These are fresh installs.
    I don't want to go back to MCS+, that whole "license only good for a year" bugs me.
    mplabx is not a viable ide for pbp3. its useful to get mpasm and the mplab ipe only for mcs use.
    if you want to use it as an ide for pbp3 then use ver 2.35 or older , none of which will allow use a pk4 of course
    or use xc8 "C" with latest mplabx
    Yeah, just found out the latest MPLAB stops at PICKIT3. What a freaking mess.
    Name:  MPLAB first attempt.png
    I was out of the game for nearly 15 years; the talk of losing MPASM confused me. I thought they were talking about PM, so I just hunched my shoulders and kept on trying.
    Going to dish out $50 for MCS+ v5 and give that a try. At least they seem intent on supporting us for now.
    Exclamation Re: Stuck on first attempt using MPLAB X
    So I get MCS+ v5, compiles like a charm, things are so simple again, tried to program, no PICKIT4 from dropdown.
    Name:  MCS+5 first attempt.png
    ARGH...
    Ah, that's why you use MPLAB IPE, as a programmer software to use PICKIT4. I don't get how you do in-circuit debugging though...?
    MPLAB IPE keeps saying
    The configuration is set for the target board to supply its own power but no voltage has been detected on VDD. Please ensure you have your target powered up and try again.
    My Lab-X1 is powered, the LCD displays the old text from my last project on it. I must have something wired wrong, or I'm not configuring the IPE properly.
    Gonna check that tomorrow. Time for bed. I can't even imagine how confusing this must be for newcomers.
    the only over priced dev boards i have are a easypic7 and a handful of curiosity boards [ i usually home brew them ] so you are on your own re dev board connections and settings.
    that has been impossible since mplabx 2.35 [for a poor result] , you need to go back to mplab to do it well
    xc8 is the answer , forget pbp
    If you want all the goodies a modern IDE provides, as Richard noted, forget ancient basic laguage. Go for a new C compiler that supports all new and wonderfull PIC that i wish could use right now. Such as the 18F06Q41.
    But PBP3.1 can work with MPLABX 5.35, not beyond that version.
    There are other compilers, for example Swordfish that supports only 18F series, but is updating regularly the PIC that it supports. Also Proton Compiler is also a nice solution as it gets support by a large group of users and supports even dsp and 24 series.
    I am very sorry to say that PBP is dead and we have to accept that. It won't evolve any more. It was a great compiler and could be the greater of all but people are getting old, retired or leaving this vain world...
    re icsp directly from mcs see below, a snap is pretty much a pk4, microchip cmd-line i/f for programmers is pretty standard(ish) [for microchip]
    not difficult just awkward
    https://www.picbasic.co.uk/forum/sho...t=command+line
    also
    https://support.melabs.com/forum/pic...ity-board-pkob
    and hardly worth the effort
  1. Replies: 19
    Last Post: - 16th May 2023, 18:06
  2. My serial to parallel attempt
    By johndoug in forum mel PIC BASIC Pro
    Last Post: - 4th January 2013, 05:15
  3. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 02:15
  4. MPLAB Quickbuild stuck on
    By RichardBowser in forum mel PIC BASIC Pro
    Last Post: - 9th July 2006, 03:52
  5. First attempt at coding
    By bartman in forum mel PIC BASIC
    Last Post: - 10th November 2004, 18:52
Members who have read this thread : 11
