Graphical Displays with PBP3
+ Reply to Thread
Results 1 to 40 of 115
    Default Re: Graphical Displays with PBP3
    one more thing
    both pbp and mpasm have limitations on line length , exceed them at your peril
    and always have an even number of bytes ie not odd on every line line other wise pbp will pad the odd byte with an extra 00 the offset indexing will fail.
    do not add or delete any byte to the file or else the offset indexing will fail.
    Dec 2010
    Melbourne Australia
    Got it and working perfectly
    Thanks again,
    Good info! Thanks.
    Is this referred to somewhere?
    Dec 2010
    Melbourne Australia
    Richard,
    I'm just starting to experiment with displaying a simple number count ie. clearing the screen, incrementing a number and displaying that number using the larger numerical font and looping that process. So, everything's good until I'm getting to either 6 or 7 loops (doesn't matter what number I start with) and then something happens. The count stops where it should be displayed and appears to continue... like... 20 or so pixels above the nominated location and the font is now only 1 pixel high.
    Any ideas what's happening or what I'm doing wrong?
        DEFINE OSC 64
        #DEFINE colours 1   ;1 mono 2 rg or 3 rgb
        width  con 128      ;
        height con 64      ;
        'use serial i/f
        #define  stserial 1
        include "grx.pbpMOD"
        include "st7920b.pbpmod"
        include "font.bas"
        include "bignum.bas"
        include "bigchr.bas"
        BUFF       VAR BYTE[4]
        ani_h var word  bank0
        ani_r var byte
        ani_c var byte
        OSCCON=$70
        OSCTUNE.6=1
        while ! osccon2.7 :WEND    ;wait for pll
        ANSELB=0
        ANSELC=0
        ANSELA=0
        'trisc = %11010101 ;cs,sck,sdo are output
        TRISB = %11111111
        TRISA = %11111111
    n var word
        gosub st7920_init    'graphic mode
        OSCCON=$70
        OSCTUNE.6=1
        ANSELB=0
        ANSELC=0
        ANSELA=0
        Pause  500      ' LCD initialize time
        lcdout $FE,1
        n=0
     main
        gosub grf_clr
        n= n+1
        SETFONT bignum
        ARRAYWRITE BUFF,[dec4 n]
        DMDSTR 40,30, Buff,1
        gosub show
    BUFF VAR BYTE[4] is too small to hold a 4 digit null terminated string it must be digits + 1
    ARRAYWRITE BUFF,[dec4 n] is not a null terminated string ARRAYWRITE BUFF,[dec4 n,0] is
    SETFONT bignum should not be in the loop , you only need to set the font once unless you want to change to another font
    rather than clearing the whole screen you can "FILLRECT" with the background colour for a restricted area to clr
         DEFINE OSC 64
        width  con 128      ;
        height con 64      ;
        'use serial i/f
        #define  stserial 1
        include "font.bas"
        BUFF       VAR BYTE[32]
        OSCCON=$70
        OSCTUNE.6=1
        ANSELB=0
        ANSELC=0
        ANSELA=0
        TRISB = %11111111
        TRISA = %11111111
        n var word
        OSCCON=$70
        OSCTUNE.6=1
        ANSELB=0
        ANSELC=0
        ANSELA=0
        lcdout $FE,1
        gosub grf_clr
        n=0
        SETFONT bignum
        n= n+1
        colour=bgcolour
        fillrect 39,29,70,20 ; this is a guess about your font size
        gosub show
    Dec 2010
    Melbourne Australia
    Good suggestions thanks again. Yeah ARRAYWRITE BUFF,[dec4 n,0] was producing the same results so I changed it to see what happened and didn't get around to changing it back - will do though.
    Troy
    Dec 2010
    Melbourne Australia
    One more thing - it's a monochrome LCD display, so the colour of the clearing rectangle would be 0 ?
    Troy
    COLOUR [COLOUR] = 1 OR 0
    BACKGROUND COLOUR [BGCOLOUR] = 1 OR 0
    take your pick provided COLOUR <> BGCOLOUR for writing stuff that you can see
  1. Replies: 3
    Last Post: - 1st January 2021, 21:28
  2. problem using Graphical LCD
    By Mostafa in forum mel PIC BASIC Pro
    Last Post: - 18th July 2007, 18:15
  3. Graphical LCDs
    By T.Jackson in forum General
    Last Post: - 14th May 2007, 06:29
  4. Vb 6.0 Graphical plug in
    By rocky79 in forum Serial
    Last Post: - 8th March 2006, 18:42
  5. Graphical user interface
    By rocky79 in forum mel PIC BASIC Pro
    Last Post: - 15th October 2005, 12:25
Members who have read this thread : 26
