BUFF VAR BYTE[4] is too small to hold a 4 digit null terminated string it must be digits + 1
ARRAYWRITE BUFF,[dec4 n] is not a null terminated string ARRAYWRITE BUFF,[dec4 n,0] is
SETFONT bignum should not be in the loop , you only need to set the font once unless you want to change to another font
rather than clearing the whole screen you can "FILLRECT" with the background colour for a restricted area to clr
Code:DEFINE OSC 64 #DEFINE colours 1 ;1 mono 2 rg or 3 rgb width con 128 ; height con 64 ; 'use serial i/f #define stserial 1 include "grx.pbpMOD" include "st7920b.pbpmod" include "font.bas" include "bignum.bas" include "bigchr.bas" BUFF VAR BYTE[32] OSCCON=$70 OSCTUNE.6=1 while ! osccon2.7 :WEND ;wait for pll ANSELB=0 ANSELC=0 ANSELA=0 'trisc = %11010101 ;cs,sck,sdo are output trisc = %11010101 ;cs,sck,sdo are output TRISB = %11111111 TRISA = %11111111 n var word gosub st7920_init 'graphic mode OSCCON=$70 OSCTUNE.6=1 while ! osccon2.7 :WEND ;wait for pll ANSELB=0 ANSELC=0 ANSELA=0 Pause 500 ' LCD initialize time lcdout $FE,1 gosub st7920_init 'graphic mode gosub grf_clr n=0 SETFONT bignum main: n= n+1 colour=bgcolour fillrect 39,29,70,20 ; this is a guess about your font size ARRAYWRITE BUFF,[dec4 n,0] DMDSTR 40,30, Buff,1 gosub show pause 1000 goto main
