Battery power back-uped circuit
Results 1 to 29 of 29
    Default Re: Battery power back-uped circuit
    Hi, Flotul,
    Those BMS are not always installed ...
    I have dozens of LiPo / LiFe batts home and only one has it included ... so, consider it's not mandatory !!!
    sometimes, there's only a fuse !!!
    my experience to date is that the bms is far more likely to fail before the battery and that it will then do its best to destroy the battery utterly.
    i have had good success in removing failed bms modules to discover perfectly good batteries . better bms modules are cheap and plentiful.
    just because they won't take a charge is not always a dead battery
    Jan 2006
    Istanbul
    Quote Originally Posted by Acetronics2 View Post
    Hi, Flotul,
    I agree with this.
    When we order batts, there is option having it with the protection; As it is an option and if you have a smart charging circuit, then it just additional cost which I think is unnecessary.
    The ones with the protectioın we received have higher failure return rate than those without the protection. Circuit burns out eventhough there is nothing wrong with the charging.
    Lithium batts should be under surveillance either charging or discharging.
    The little circuits are supposed to work in either case, not allowing overcharge or flat discharge the batteries. The second is important as many devices continue to drain the batteries to very low levels, finally destroying them.
    It is really annoying that the protection circuits fail...
    SWITZERLAND (french speaking)
    Default Let's build it!
    Hi All,
    I'm now (finally...) building my project and its about time to order the missing components to have something to play with (without any reference to naughty thoughts ).
    So, here's the circuit I'm building:
    Name:  Power SIM7600 backup.jpg
    Reading the (very interesting) MicroChip's AN1149 about battery charge and power backup, I can see that a particular attention is to be paid to the choice of the Q1's (the P-Mosfet) where a "proper" Vgs(th) has to be chosen.
    Unfortunately, I'm not an electronician, just an electrician creating himself (lots of) problems with this PIC stuff = I don't know how to calculate or determine with exactitude how to dimension the needed P-chanel Mosfet
    Can anyone help me out and suggest a component (according to the DS, a combined S-diode and Mosfet is nice) or the Vgs(th) value I will have to find to make my circuit work? Instead, I would appreciate someone explain me how to "calculate" this Vgs(th) I'll need....
    Roger
    Default Re: Let's build it!
    BTW, I don't think the above schema will work.
    Is this really correct?
    Name:  Power SIM7600 backup 2.jpg
    Shouldn't it be something more like this?
    Name:  Power SIM7600 backup 3.jpg
    Roger
    Sep 2009
    First schematic can work. But MOSFET have no purpose. There is no need for one.
    Second schematic doesn't allow battery discharge when charging.
    Don't know where you found that schematic, but look at
    http://ww1.microchip.com/downloads/e...tes/01149c.pdf
    Page 2.
    Thanks pedja,
    The schemas come from this exact document you refer to in your last post, adapted to DC supply.
    Can you please explain?
    Without any "switch" (MOSFET in this cas, how I understand it), how would hte load be fed either by the main supply or the battery in case of main supply failure?
    Roger
  1. How to detect low battery in battery powered F683 circuit
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 21st May 2015, 19:20
  2. Auto power off back light with 16F84A
    By manojsoorya in forum FAQ - Frequently Asked Questions
    Last Post: - 12th April 2014, 15:14
  3. Back from 6 yrs away - best in circuit programmer/breadboard?
    By PickyPerson in forum mel PIC BASIC Pro
    Last Post: - 27th January 2012, 05:21
  4. 4.5V Battery charging circuit....
    By Megahertz in forum Schematics
    Last Post: - 2nd July 2010, 01:33
  5. Replies: 1
    Last Post: - 20th December 2005, 04:56
