Battery power back-uped circuit
Results 1 to 29 of 29
    Default Re: Battery power back-uped circuit
    Hello, Flotul,
    LiPo batts are somewhat tricky to use ...
    I suggest you to use something called " BMS " with your battery ... it's a device that cares with every problem that could occur : Overchage, under voltage, load shorted ...
    that can avoid fire or exploding the battery ... not negligible !
    https://www.nkon.nl/fr/accessories/1...2mos-5530.html for example ...
    SWITZERLAND (french speaking)
    Default Battery power back-uped circuit
    Hi Alain,
    I thought these BMS circuits were already interated in the batteries?
    When I look to one of my LiPo battery, I can see some kind of a circuit at the top of it.
    I might be wrong, but I think this is a protection circuit (difficult to see okay, but believe me, there is a small circuit here ) or isn't it?
    Roger
  1. How to detect low battery in battery powered F683 circuit
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 21st May 2015, 19:20
  2. Auto power off back light with 16F84A
    By manojsoorya in forum FAQ - Frequently Asked Questions
    Last Post: - 12th April 2014, 15:14
  3. Back from 6 yrs away - best in circuit programmer/breadboard?
    By PickyPerson in forum mel PIC BASIC Pro
    Last Post: - 27th January 2012, 05:21
  4. 4.5V Battery charging circuit....
    By Megahertz in forum Schematics
    Last Post: - 2nd July 2010, 01:33
  5. Replies: 1
    Last Post: - 20th December 2005, 04:56
