Compare value ...
Results 1 to 40 of 69
    Default Re: Compare value ...
    lcdout $FE, $C0," TEmpe", temperature
    what does this line display the temperature value as ?
    Apr 2020
    ASCII code, one strange character, and it changes every time the temperature changes
    lcdout $FE, $C0," TEmpe", dec temperature
    removing all the unused/unecessary stuff " just noise" , using a proper config and displaying a result more in keeping with lm35 accuracy
    this works just fine
    '****************************************************************'*  '*  Name    : 16F88_LM235.BAS                                   *
    '*  Author  :                                    *
    '*  Notice  : Copyright (c) 2020                                *
    '*  Date    : 04/04/2020                                        *
      __config  _CONFIG1, _INTRC_IO & _WDT_ON & _PWRTE_OFF & _MCLR_ON & _BODEN_ON & _LVP_OFF & _CPD_OFF & _WRT_PROTECT_OFF & _DEBUG_OFF & _CCP1_RB0 & _CP_OFF
      __config  _CONFIG2, _FCMEN_ON & _IESO_ON
    'PIC 16F88
    '    Hardware Assignments
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    adcon1.7=1
    ANSEL = %000001 'Disable Inputs Tranne AN0
    OSCCON = %01100000 'Internal RC set to 4MHZ
    TRISA = %10111111 ' impostazioni INP/OUT
    TRISB = 0 ' delle porte
    DEFINE LCD_DREG PORTB       'Porta B DATA OUT
    DEFINE LCD_DBIT 4           '0 --> Bit 0-3 : 4 --> Bit 4-7
    DEFINE LCD_RSREG PORTB      'LCD register select port - Porta B --> RS
    DEFINE LCD_RSBIT 2          'LCD register select bit  - Pin RS B2
    DEFINE LCD_EREG PORTB       'LCD enable port - Porta B --> EN
    DEFINE LCD_EBIT 3           'LCD enable bit - Pin EN B3DEFINE LCD_BITS 4           'LCD bus size 4 or 8
    DEFINE LCD_LINES 2          'Number lines on LCD DEFINE LCD_COMMANDUS 2000   'Command delay time in us
    DEFINE LCD_DATAUS 50        'Data delay time in us
    '    EEPROM Locations Codice ASCII es. a=97 b=98 c=99 ...
    '*****  SETTAGGIO PORTE
    Rele   VAR    PORTA.6     '                  Pin 15
    '---------Define ADCin Parameters
    DEFINE ADC_BITS 10      'set number of bits in result
    DEFINE ADC_CLOCK 3      'set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50  'Set sampling time in uS
    '    RAM Assignments and Variables
    temp var word
    temperature var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    Lcdout $FE, 1           'Clear screen
    rele=0
    samples=0
    FOR sample = 1 TO 20 'Take 20 samples
    ADCIN 0, temp 'Read AN0 into temp variable
    samples = samples + temp
    PAUSE 40 ' Wait 1/4 seconds per reading
    NEXT sample
    temp = samples/20 'Average over 20 samples (Every 5 seconds)
    temperature= temp */ quanta
    LCDOUT $FE, 1 ' cancella LCD
    LCDOUT $FE, 2 ' ritorna al primo carattere
    lcdout $FE, 2, "Temp ",dec2 (temperature/10),".", dec1 (temperature//10),$DF,"C"
    If temperature > (Tmax*10) then
    rele=1
    rele=0
    Endif
  1. How to compare two temperatures
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2012, 10:07
  2. how to hserin compare with known value?
    By aa222k in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2010, 19:48
  3. Is there a faster way to compare?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th February 2010, 20:48
  4. how to compare data
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 23:30
  5. Compare Data
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 21:40
