Originally Posted by
louislouis
I think, You want this:
Here is a Richard's corrected and tested code. I hope it will be works:
'****************************************************************'* '* Name : 16F88_LM235.BAS *
'* Author : *
'* Notice : Copyright (c) 2020 *
'* : All Rights Reserved *
'* Date : 04/04/2020 *
'* Version : 1.0 *
__config _CONFIG1, _INTRC_IO & _WDT_ON & _PWRTE_OFF & _MCLR_ON & _BODEN_ON & _LVP_OFF & _CPD_OFF & _WRT_PROTECT_OFF & _DEBUG_OFF & _CCP1_RB0 & _CP_OFF
__config _CONFIG2, _FCMEN_ON & _IESO_ON
'PIC 16F88
' Hardware Assignments
' LCD circuitery
'01 - Vss (GND)
'02 - Vdd (+5V)
'08 RS - PORTB.2
'09 E - PORTB.3
'10 DB4 - PORTB.4
'11 DB5 - PORTB.5
'12 DB6 - PORTB.6
'13 DB7 - PORTB.7
adcon1.7=1
ANSEL = 0001 'Disable Inputs Tranne AN0
OSCCON = 100000 'Internal RC set to 4MHZ
TRISA = 111111 ' impostazioni INP/OUT
TRISB = 0 ' delle porte
DEFINE LCD_DREG PORTB 'Porta B DATA OUT
DEFINE LCD_DBIT 4 '0 --> Bit 0-3 : 4 --> Bit 4-7
DEFINE LCD_RSREG PORTB 'LCD register select port - Porta B --> RS
DEFINE LCD_RSBIT 2 'LCD register select bit - Pin RS B2
DEFINE LCD_EREG PORTB 'LCD enable port - Porta B --> EN
DEFINE LCD_EBIT 3 'LCD enable bit - Pin EN B3DEFINE LCD_BITS 4 'LCD bus size 4 or 8
DEFINE LCD_LINES 2 'Number lines on LCD DEFINE LCD_COMMANDUS 2000 'Command delay time in us
DEFINE LCD_DATAUS 50 'Data delay time in us
' EEPROM Locations Codice ASCII es. a=97 b=98 c=99 ...
'***** SETTAGGIO PORTE
Rele VAR PORTA.6 ' Pin 15
'---------Define ADCin Parameters
DEFINE ADC_BITS 10 'set number of bits in result
DEFINE ADC_CLOCK 3 'set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 'Set sampling time in uS
' RAM Assignments and Variables
temp var word
temperature var word
samples var word
sample VAR BYTE
quanta con 1250
Tmax VAR byte
Tmin VAR byte
Tmin=16
Tmax=30
START:
Lcdout $FE, 1 'Clear screen
rele=0
sample = 1
samples= 0
FOR sample = 1 TO 20 'Take 20 samples
ADCIN 0, temp 'Read AN0 into temp variable
samples = samples + temp
PAUSE 50 ' Wait 1/4 seconds per reading
NEXT sample
temp = samples/20 'Average over 20 samples (Every 5 seconds)
temperature= temp */ quanta
LCDOUT $FE, 2 ' ritorna al primo carattere
lcdout $FE, 2, "Temp ",dec2 (temperature/10),".", dec1 (temperature/10),"C"
lcdout $FE, $C0, "Tmin ",#Tmin, " Tmax ",#Tmax
If temperature > (Tmax*100) then
rele=1
rele=0
Endif
Your video is OK!
and the code is similar to mine, except for the initial strings.
without too much hesitation, however, I did copy and paste of your source in my compiler
Microcode Studio Plus 3.0.0.5
and as soon as I tried to issue the compile command it gave me errors.
ERROR Line 11: Syntax error. (louislouis.pbp)
ERROR Line 12: Syntax error. (louislouis.pbp)
ERROR Line 13: Redefiniton of LABEL __config. (louislouis.pbp)
ERROR Line 13: Syntax error. (louislouis.pbp)
ERROR Line 14: Syntax error. (louislouis.pbp)
What are all those strings? why won't my compiler accept them?
