Compare value ...
Results 1 to 40 of 69
    Default Re: Compare value ...
    OK, please program this HEX and tell what number shown on display. Then warm up the sensor with fingers or soldering iron. The numbers should be arround 600 for 30degC and 700 for 35degC and so on.
    This test the ADC reading on your PIC.
    Apr 2020
    [QUOTE = louislouis; 145048] OK, si prega di registrare questo esadecimale e dire quale numero mostrato sul display. Quindi riscaldare il sensore con le dita o il saldatore. I numeri devono essere intorno a 600 per 30 ° C e 700 per 35 ° C e coś via.
    Questo test la lettura ADC sul PIC. [/ QUOTE]
    Prima di installare questo firmware il display mostrava 25,5 ° C.
    Con questo firmware sul display della legge 665.
    Tenendo il sensore tra le dita puoi vedere il valore salire 670, 674, 677.679 ... ecc.
  1. How to compare two temperatures
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2012, 10:07
  2. how to hserin compare with known value?
    By aa222k in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2010, 19:48
  3. Is there a faster way to compare?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th February 2010, 20:48
  4. how to compare data
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 23:30
  5. Compare Data
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 21:40
