Interfacing with Arduino I2C LCD
Results 1 to 40 of 48
    Default Re: Interfacing with Arduino I2C LCD
    "LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE)"
    interpreted as [( 7bit_addr, EN, RW, RS, D4, D5, D6, D7, Backlight, POLARITY) ]
    the PCF8574 datasheet indicates the 7bit addr range is 0x20--0x27
    0x3f is not valid afaik.
    default with a0:2 open = 7bit_addr of 0x27 , pbp addr would be $4e
    Mar 2008
    I see on the data sheet for the PCF8574 you are right I used the Arduino i2c address finder to get the address. I have tried it using the 4E address and get nothing however with the 7E I do get some response from the display. I am still trying to understand the Initialization string and how to use it if you can offer guidance it would be appreciated. This is a little beyond my current ability but I will continue to try to learn and get this project going.
    Thank You!
    did it work with the Arduino sketch ?
    if so what was the init command [I assume a0:2 are open]
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE) or LiquidCrystal_I2C lcd(0x27, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE);
    afaik there is at least two types there may be others.
    if the addr is not between 0x20 and 0x27 then its a going to be different animal and the include files may need modification
    would not hurt to trace out the cct and see what bits are wired to rs,e,rd/wr etc
    Mar 2008
    This is the init command from my working Arduino sketch "LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE)" all three jumpers are open A0:2.
    Thanks!
    ok must be PCF8574A [addr range 0x38-0x3f]
    so $7e is sounding good for an address , one of those includes should work .
    another thought
    you did not specify osc speed you may need
    DEFINE I2C_SLOW 1
    Make sure of the IC Type. A PCF8574 (non A) has an upper nibble of 4 for the address and the PCF5874A version has an upper nibble of 7 for the address. NXP did this to allow upto 16 devices on the I2C bus.
    EN82fn
    Mar 2008
    PCF8574AT is the number on my IC.
  1. Another Arduino clone that uses a PIC
    By dhouston in forum PBP & Amicus18
    Last Post: - 7th March 2012, 20:14
  2. Arduino ?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 13th September 2011, 20:50
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Arduino
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 1st July 2011, 20:11
  5. ARDUINO? -- what is it?
    Last Post: - 18th August 2009, 01:19
Members who have read this thread : 6
