Interfacing with Arduino I2C LCD
Results 1 to 40 of 48
    Default Re: Interfacing with Arduino I2C LCD
    So I'm not missing a label then, the code just isn't terminated "properly".
    I kept going through it thinking I was missing something obvious.
    Jun 2009
    Sc*nthorpe, UK
    Not that I can see but then I always wonder if I am missing something whether it is obvious or not.
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $48
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $45
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $4C
    GOSUB LCDWRITE
    I have been trying to work out what the $44 do because they are not printed on the screen.
    Can't find info on $44, and can't see what's in this zip on my phone:
    https://bitbucket.org/fmalpartida/ne...stal/downloads
    I'd be curious to see all the stuff in version 1.2.1.
    Jun 2009
    Sc*nthorpe, UK
    Compare this code with Darrel's the one obvious issue is that the LCD is in 4 bit mode which requires the upper nibble and lower nibble to be sent separately. One other concern is that of setting the RS bit for data mode which is done once after initialisation. Does this not need doing every time a data nibble is sent?
    Jun 2009
    Sc*nthorpe, UK
    Is it pure coincidence that all the upper nibbles are $4?
    Jun 2013
    I believe this may be my first post to this forum...
    Has anyone figured more of this out? I finally got my I2C serial adapter for the 1602 LCD to do something at least.
    It was indeed very helpful to see the original code posted. Somehow my default address is $40.
    When I use the code provided, I do get the display to light up and display "HELLO RCG! but when I try to change the initials to DHD, using the hex codes for D = $44, H=$48, and D=$44, I get THD in the display.
    I am also looking for a bit more help with the control characters, and why the LCDWRITE routine needs 3 i2cwrite commands.
    Thanks from noob Dave
    Jun 2009
    Sc*nthorpe, UK
  1. Another Arduino clone that uses a PIC
    By dhouston in forum PBP & Amicus18
    Last Post: - 7th March 2012, 19:14
  2. Arduino ?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 13th September 2011, 19:50
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 02:28
  4. Arduino
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 1st July 2011, 19:11
  5. ARDUINO? -- what is it?
    Last Post: - 18th August 2009, 00:19
Members who have read this thread : 4
