Interfacing with Arduino I2C LCD
Results 1 to 40 of 48
    Jun 2013
    Default Re: Interfacing with Arduino I2C LCD
    Thanks to everyone that helped out.
    I have gotten a modified version of Darrel's code to run on a 12F683 which has 2K of memory.
    I am using an LCD 1602 and I don't see any Jumping Jacks.
    ; Filename    : 632-I2C-LCD for 12F683.pbp
    ; Author      : Darrel Taylor
    ; Created     : Mon Feb 24 2014
    ;             : May 27, 2015 adapted for the 12F683
    ; Processor   : PIC12F683
    ; Compiler    : PicBasic Pro 3.0.7.x or higher
    ; Description : Uses PCF8574 Port expander to interface with HD44780 LCD
    ;----[Oscillator Setup]---------------------------------------------------------
    define OSC 20
    define I2C_SLOW 1
    ;----[Aliases]------------------------------------------------------------------
    SDA         VAR GPIO.0       ; I2C Data pin
    SCL         VAR GPIO.1       ; I2C Clock Pin
    ;----[Initialize Hardware]------------------------------------------------------
    ANSEL = 0             ; Make Analog inputs digital
    ';----[Setup LCD using PCF8574 Port Expander]------------------------------------
    LCD_Addr    CON $40           ; A0, A1, A2 grounded
    true        con 1
    false       con 0
    INCLUDE "LCD_PCF8574.pbp"     ;  Init LCD using I2C and PCF8574
    ;----[Variables]----------------------------------------------------------------
    LoopCount   VAR BYTE
    CustChar    VAR BYTE
    ;----[Program Start]------------------------------------------------------------
    Backlight = 0                 ; Turn on LCD Backlight
    LoopCount     = 0
    ARRAYWRITE LCD_Buff,["   LCD PCF8574"] : LCD_WriteBuff
    ;----[Custom Characters]-(Jumping Jacks)----------------------------------------
    ARRAYWRITE LCD_Buff,[$FE,$40,$00,$04,$0A,$04,$0E,$15,$0A,$11]:LCD_WriteBuff ' #0
    ARRAYWRITE LCD_Buff,[$FE,$48,$00,$04,$0A,$04,$1F,$04,$0A,$0A]:LCD_WriteBuff ' #1
    ARRAYWRITE LCD_Buff,[$FE,$50,$04,$0A,$15,$0E,$04,$0A,$0A,$00]:LCD_WriteBuff ' #2
    ;----[Main Program Loop]--------------------------------------------------------
       ARRAYWRITE LCD_Buff,[$FE,$C0,"Count = ",DEC LoopCount,"   "] : LCD_WriteBuff
       PAUSE 200
       LoopCount = LoopCount + 1
       CustChar = LoopCount//3   ; Jumping Jacks Sequence
       ARRAYWRITE LCD_Buff,[$FE,$9D,CustChar] : LCD_WriteBuff
    GOTO Main
    Jun 2013
    Commented out the lines...
    and
    Changed the $9D to a $C0 in
    ARRAYWRITE LCD_Buff,[$FE,$C0,CustChar] : LCD_WriteBuff ' $C0 was $9D
    and now the little guy is doing Jumping Jacks in the lower left hand corner.
    Thanks again!
    Mar 2008
    I am trying to make this code work with a 16F629A and all I get is a blinking back light with the modified code below.I am probably missing something simple?
    ; Filename : Test_LCD_PCF8574.pbp
    ; Processor : 16F629A
    ; Compiler : PicBasic Pro 3.0.6.x or higher
    ;----[16f629A Hardware Configuration]-------------------------------------------
    #config
    __config _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_ON & _BODEN_OFF
    #endconfig
    SDA var porta.7
    SCL var porta.6
    CMCON = 7 'CHANGES PORTA TO DIGITAL
    LCD_Addr CON $7E
    INCLUDE "LCD_PCF8574.pbp" ; Include LCD module for PCF8574
    LoopCount VAR BYTE
    CustChar VAR BYTE
    LoopCount= 0
    PAUSE 200
    GOTO Main
    Mar 2008
    I did delete these two lines
    and Change this line
    16F629A ?
    might you mean 12f629 ?
    if so you need to set the " lcd " pins to digital
    Mar 2008
    Sorry, I should have said 16F628A. I did set my pins as digital? I want to display data from my program but that seems far away at this point?? I cut the program down to the below lines and I get a custom character and a blinking cursor the backlight stays on. I guess that is progress ?
    Thank You!
    ;----[16f628A Hardware Configuration]-------------------------------------------
    #config
    #endconfig
    SDA var porta.7
    SCL var porta.6
    LCD_Addr CON $7E
    GOTO Main
    there is more info here . note the slightly differing versions of the include
    INCLUDE "LCD_PCF8574a.pbp" ; Include LCD module for PCF8574
    http://support.melabs.com/threads/10...hlight=PCF8574
    ps
    LCD_Addr CON $7E is way different to addr used in above threads
  1. Another Arduino clone that uses a PIC
    By dhouston in forum PBP & Amicus18
    Last Post: - 7th March 2012, 19:14
  2. Arduino ?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 13th September 2011, 19:50
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 02:28
  4. Arduino
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 1st July 2011, 19:11
  5. ARDUINO? -- what is it?
    Last Post: - 18th August 2009, 00:19
Members who have read this thread : 5
