Interfacing with Arduino I2C LCD
Results 1 to 40 of 48
    Default Re: Interfacing with Arduino I2C LCD
    Norohs,
    If you have seen any of my code you will see that I am the last on to criticize others code. You original post seemed like it could have been an advertisement, if it was it should be moved to another section.
    Being it was to show a project working, then posting your code could help someone. Do not worry about what your code looks like or how inefficient you think it is. As long as it works. Sometimes that is all someone needs.
    Oct 2012
    Feel free to move it.
    Oct 2012
    'ARDUINO IIC LCD GY-LCD-V1
    'PIC 12F629
    'PRINTS " HELLO RCG!_"
    Define OSC 20
    DEFINE I2C_SLOW 1
    CMCON = $7
    OPTION_REG.7 = 0
    C VAR GPIO.1
    D VAR GPIO.0
    ADDR VAR BYTE
    ADDR = $40
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT4
    RS VAR LCD_CMD.BIT6
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    LCD_CMD = $2
    GOSUB LCDWRITE
    GOSUB LCDWRITE
    LCD_CMD = $8
    GOSUB LCDWRITE
    LCD_CMD = $0
    GOSUB LCDWRITE
    LCD_CMD = $E
    GOSUB LCDWRITE
    LCD_CMD = $0
    GOSUB LCDWRITE
    LCD_CMD = $6
    GOSUB LCDWRITE
    RS=1
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $48
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $45
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $4C
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $4C
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $4F
    GOSUB LCDWRITE
    LCD_CMD = $42
    GOSUB LCDWRITE
    LCD_CMD = $40
    GOSUB LCDWRITE
    LCD_CMD = $45
    GOSUB LCDWRITE
    LCD_CMD = $42
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $43
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $47
    GOSUB LCDWRITE
    LCD_CMD = $42
    GOSUB LCDWRITE
    LCD_CMD = $41
    GOSUB LCDWRITE
    LCDWRITE:
    I2CWRITE D,C,ADDR,[LCD_CMD]
    E=1
    E=0
    Jun 2009
    Sc*nthorpe, UK
    Has anyone done this?
    I have downloaded the Aduino LCD libraries and there are differences between them and the above code.
    Just curious where RETURN right before LCDWRITE subroutine returns to?
    Don't have one to test.
    Jun 2009
    Sc*nthorpe, UK
    From what I have read the code is correct in that it will print to the LCD on a one shot basis then return to nowhere.
    Return to nowhere?
    Does anyone have one to test?
    Having used serial LCDs which were easy to use by sending ascii commands and data using serout2 these look very difficult. I just wonder why make something difficult when there is an easier way.
    I have done more research and I believe that all Arduino I2C LCDs are not the same. I guess it depends on the manufacturers implementation and the chips used on the backpack.
    So I'm not missing a label then, the code just isn't terminated "properly".
    I kept going through it thinking I was missing something obvious.
  1. Another Arduino clone that uses a PIC
    By dhouston in forum PBP & Amicus18
    Last Post: - 7th March 2012, 20:14
  2. Arduino ?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 13th September 2011, 20:50
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Arduino
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 1st July 2011, 20:11
  5. ARDUINO? -- what is it?
    Last Post: - 18th August 2009, 01:19
