Interfacing with Arduino I2C LCD
Results 1 to 40 of 48
    Default Re: Interfacing with Arduino I2C LCD
    Darrel Taylor's program seems to be a work of art but I think with the INCLUDE, it's just too big for my 12F629 as I am getting, "Unable to fit variable" errors.
    I did not realise you were using a pic12f the dt code won't work on those chips because
    ARRAYWRITE is not supported on 12-bit core PIC MCUs due to RAM and stack
    constraints
    Jun 2013
    I believe Darrel Taylor was using a 12F1822. Doesn't that have the same "bit core" as my 12F629?
    According to the Microchip datasheet on the 12F1822,
    "This family of devices contains an enhanced mid-range 8-bit CPU core"
    Jun 2013
    The PIC numbering system was getting me confused so I spoke to an engineer at Microchip and this is what I was told...
    The 12 in the 12F629 means it is an 8 pin chip. (I didn't ask why 12 means 8 or why they just didn't just call it an 8Fxxx)
    The 6 after the F means that it has a 14 bit memory core, since anything other (? # > 5) has a 14 bit memory core.
    A 12F5xx chip would be an 8 pin chip with a 12 bit memory core...
    So it does not seem to a 12-bit core problem but rather an overall memory problem.
    The 12F629 has 1k x 14 memory (there's that 14 bit core again), where as
    the 12F1822 has 2K 14 memory.
    I ordered some 12F1822s to see if I can get Darrel's program working.
    Jun 2013
    Here is the thread in which I believe Darrel was using a 12F1822.
    Post #3
    http://support.melabs.com/threads/98...F8574-20x4-LCD
    Jun 2013
    Hmmm, unfortunately, I just figured out that my Silver version of PBP3.0 doesn't support the 12F1822...
    a pic12f1xxx is an enhanced midrange device . they have twice the stack capacity of a 12f6xx device , apart from more memory etc ....
    Jun 2013
    Thanks to everyone that helped out.
    I have gotten a modified version of Darrel's code to run on a 12F683 which has 2K of memory.
    I am using an LCD 1602 and I don't see any Jumping Jacks.
    ; Filename    : 632-I2C-LCD for 12F683.pbp
    ; Author      : Darrel Taylor
    ; Created     : Mon Feb 24 2014
    ;             : May 27, 2015 adapted for the 12F683
    ; Processor   : PIC12F683
    ; Compiler    : PicBasic Pro 3.0.7.x or higher
    ; Description : Uses PCF8574 Port expander to interface with HD44780 LCD
    ;----[Oscillator Setup]---------------------------------------------------------
    define OSC 20
    define I2C_SLOW 1
    ;----[Aliases]------------------------------------------------------------------
    SDA         VAR GPIO.0       ; I2C Data pin
    SCL         VAR GPIO.1       ; I2C Clock Pin
    ;----[Initialize Hardware]------------------------------------------------------
    ANSEL = 0             ; Make Analog inputs digital
    ';----[Setup LCD using PCF8574 Port Expander]------------------------------------
    LCD_Addr    CON $40           ; A0, A1, A2 grounded
    true        con 1
    false       con 0
    INCLUDE "LCD_PCF8574.pbp"     ;  Init LCD using I2C and PCF8574
    ;----[Variables]----------------------------------------------------------------
    LoopCount   VAR BYTE
    CustChar    VAR BYTE
    ;----[Program Start]------------------------------------------------------------
    Backlight = 0                 ; Turn on LCD Backlight
    LoopCount     = 0
    ARRAYWRITE LCD_Buff,["   LCD PCF8574"] : LCD_WriteBuff
    ;----[Custom Characters]-(Jumping Jacks)----------------------------------------
    ARRAYWRITE LCD_Buff,[$FE,$40,$00,$04,$0A,$04,$0E,$15,$0A,$11]:LCD_WriteBuff ' #0
    ARRAYWRITE LCD_Buff,[$FE,$48,$00,$04,$0A,$04,$1F,$04,$0A,$0A]:LCD_WriteBuff ' #1
    ARRAYWRITE LCD_Buff,[$FE,$50,$04,$0A,$15,$0E,$04,$0A,$0A,$00]:LCD_WriteBuff ' #2
    ;----[Main Program Loop]--------------------------------------------------------
       ARRAYWRITE LCD_Buff,[$FE,$C0,"Count = ",DEC LoopCount,"   "] : LCD_WriteBuff
       PAUSE 200
       LoopCount = LoopCount + 1
       CustChar = LoopCount//3   ; Jumping Jacks Sequence
       ARRAYWRITE LCD_Buff,[$FE,$9D,CustChar] : LCD_WriteBuff
    GOTO Main
    Jun 2013
    Commented out the lines...
    and
    Changed the $9D to a $C0 in
    ARRAYWRITE LCD_Buff,[$FE,$C0,CustChar] : LCD_WriteBuff ' $C0 was $9D
    and now the little guy is doing Jumping Jacks in the lower left hand corner.
    Thanks again!
  1. Another Arduino clone that uses a PIC
    By dhouston in forum PBP & Amicus18
    Last Post: - 7th March 2012, 19:14
  2. Arduino ?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 13th September 2011, 19:50
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 02:28
  4. Arduino
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 1st July 2011, 19:11
  5. ARDUINO? -- what is it?
    Last Post: - 18th August 2009, 00:19
Members who have read this thread : 5
