Single PIC to Blink 5 LEDs Independently?
Results 1 to 40 of 69
    Default Re: Single PIC to Blink 5 LEDs Independently?
    No argument from me, SteveB - the elegance of the solution is indeed beautiful!
    Would I gain any better resolution/exactitude of timings by increasing the oscillator? The 16F1825 can go up to 32Mhz internal with the pullup enabled. I've added to Darrel's solution to include another blinky without randomization of the periods, so it needs to be on for 20ms and off for 480ms (i.e. it blinks twice a second).
    Quote Originally Posted by RossWaddell View Post
    The timing is maintained by the CCP module and Timer1. Those periods will remain the same reqardless of the CPU's frequency.
    Increasing the frequency will only allow more instructions to be executed between periods.
    The way I left it, only 4.5 mS of the 10 mS periods are being used to run the 5 led's.
    You should be able to add 2 more without any problems.
    I switched to a PIC16F88 since I needed a chip which had 8 pins of the same port (i.e. PORTB0-7). I thought I had it working using RB0-6 (7 blinkies) but realized this chip has the external interrupt on RB0, which I will need for the button to toggle 'FlashMode'. So I moved everything over to PORTA and now the LED connected to RA7 kind of flickers and is no way near the 1.5 sec on/0.5 sec off flash rate set in code.
    '*  Name    : Formation_Engine_Running_Lights_16F88_4Mhz_Int.pbp*
    '*  Author  : Ross A. Waddell                                   *
    '*  Notice  : Copyright (c) 2012                                *
    '*  Date    : 10/29/2012                                        *
    '*  Notes   : Strobe lights, nacelle lights (steady-on and      *
    '*            Christmas flashers) and running lights for the    *
    '*            TOS Enterprise                                    *
    ' Pin Connections
    ' RA0                        -> Flashing lights for nacelle engines 1  (x2)
    ' RA1                        -> Flashing lights for nacelle engines 2  (x2)
    ' RA2                        -> Flashing lights for nacelle engines 3  (x2)
    ' RA3                        -> Flashing lights for nacelle engines 4  (x2)
    ' RA4                        -> Flashing lights for nacelle engines 5  (x2)
    ' RA5                        -> Dummy output (MCLR is input only)
    ' RA6                        -> Secondary hull strobe/formation lights (x2)
    ' RA7                        -> Primary hull running lights            (x4)
    ' RB0                        -> Button for toggling running light flash mode
    ' RB1                        -> Steady-on lights for nacelle engines   (x10)
    ' Secondary Hull Strobes Lights
    ' The two strobe locastions are:
    '   - Port/starboard rear secondary hull (just forward of the "1837" marking),
    '     horizontally inline with the shuttlebay flight deck
    ' The strobe light flashed at the rate of twice per second,
    ' or every 12 film frames. Since it's a strobe, it stays on
    ' for much less time than a running light; approx. .020 sec
    ' Nacelle engine lights
    ' (a) The colours used were: red, blue, green, amber and pink, all standard colours
    '     they had for common Christmas lights of the time.
    ' (b) They were all Christmas lights (C7, too big for a 1/350).
    ' (c) Amber was steady (5 in a star pattern), the other 5 blinked at various rates
    ' Running lights
    ' The running light locations on the primary hull are (4):
    '   - Saucer Port [top] (red) - 1
    '   - Saucer Starboard [top] (green) - 1
    '   - Saucer Port/Starboard [bottom (white) - 2
    ' The TOS E running lights flash at a base timing of 1-1/2 sec (36 frames) on,
    ' 1/2 sec (12 frames) off (FlashMode = 0)
    ' Alternate is 1/2 sec on, 1.5 sec off (reverse of above). (FlashMode = 1)
    ' In "The Corbomite Maneuver", the lights were on for 18 frames and off for 20
    ' (FlashMode = 2)
    ' >> These modes are available via a momentary button
    DEFINE OSC 4                 ; Set oscillator 4Mhz
    DEFINE BLINKYFREQ 100        ; 10mS periods
    ' Device Fuses
    ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
       __config _CONFIG1, _FOSC_INTOSCIO & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _LVP_OFF
    ' Initialization
    OSCCON   = %01100000         ; 4MHz internal osc
    ANSEL    = 0                 ; PIC16F88 only
    TRISA    = 0                 ; PORTA all output
    TRISB    = %00000001         ; Make PORTB pin 0 input for flash mode button
    LEDcount    CON 8                        ; Number of blinking LEDs on PORTA
    '                 BL1,BL2,BL3,BL4,BL5,MCLR,STB
    OnTimes     DATA  50 ,22 ,38 ,75 ,17 ,2   ,2  ; default "on" periods for each output
    OffTimes    DATA 150 ,45 ,38 ,95 ,117,2   ,48 ; default "off" periods for each output
                                             ; (Strobe flashes 2 times per second
                                             ; or every 500ms; subtract "on" time)
    ' Running lights will be handled slightly differently
    ' FlashMode Values
    ' 0 = 1-1/2 sec (36 frames) on,  1/2 sec (12 frames) off (Trek Ace, HobbyTalk)
    ' 1 = 1/2 sec (12 frames) on, 1-1/2 sec (36 frames) off (Master Replica model)
    ' 2 = 3/4 sec (18 frames) on, 5/6 sec (20 frames) off ("The Corbomite Maneuver")
    FlashMode_Default CON  0
    EE_FlashMode      DATA FlashMode_Default
    FlashMode         VAR  BYTE
    READ EE_FlashMode, FlashMode
    #DEFINE USE_RANDOM_SEQUENCE           ; comment for contiuous Sequence
    #IFDEF USE_RANDOM_SEQUENCE            ; randomization used for BL1-5 only
        RND     VAR WORD : RND = 13864
        MIN_ON  CON 15                    ; Minimum random ON time
        MAX_ON  CON 115                   ; Maximum random ON time
        MIN_OFF CON 15                    ; Minimum random OFF time
        MAX_OFF CON 200                   ; Maximum random OFF time
        RandPeriod VAR WORD[LEDcount-3]
        RandPeriods DATA WORD 1000, WORD 1250, WORD 1500, WORD 1750, WORD 2000
    #ENDIF
    CCPR1val      CON EXT      : @CCPR1val = (OSC*1000000/4)/ BLINKYFREQ
    ;CCPR1         VAR WORD EXT : @CCPR1 = CCPR1L
    Timer1        VAR WORD EXT : @Timer1 = TMR1L
    CCPIF         VAR PIR1.2
    LoopLED       VAR BYTE[LEDcount]
    OnTime        VAR BYTE[LEDcount]
    OffTime       VAR BYTE[LEDcount]
    x             VAR BYTE
    LED_STDY_ON   VAR PORTB.1    ; Alias PORTB.1 as "LED_STDY_ON"
    ;Old_FlashMode           VAR BYTE
    PRI_HULL_LGHTS_ON_MS    VAR BYTE
    PRI_HULL_LGHTS_OFF_MS   VAR BYTE
    ;----[Initialize on/off periods & random sequencing (if enabled)]---------------
    ;     (only set up first 7 blinkies; the 8th [running lights] is separate)
    FOR x = 0 to (LEDcount - 2)           ; Load the periods from EEPROM
        READ OnTimes+x, OnTime(x)
        READ OffTimes+x, OffTime(x)
            IF x < 5 THEN
                READ RandPeriods+(x<<1), WORD RandPeriod(x)
        #ENDIF
    NEXT X
    GOSUB SetFlashRates    ; Set up flash rates based on saved "FlashMode" val
    ;-- setup CCP1 and Start Timer1 --
    CCPR1   = CCPR1val     ; set compare value
    CCP1CON = %00001011    ; compare mode, special event
    Timer1  = 0            ; clear Timer1
    T1CON.0 = 1            ; start Timer1
    HIGH LED_STDY_ON       ; Turn on steady-on LEDs
    ;----[Main Program Loop]----------------------------------------
        x = (x + 1) // LEDcount
        PORTA.0(x) = !!(LoopLED(x) < OnTime(x))
        LoopLED(x) = (LoopLED(x) + 1) // (OnTime(x) + OffTime(x))
            IF x < 5 THEN
                RandPeriod(x) = RandPeriod(x) - 1
                IF RandPeriod(x) = 0 THEN
                    RANDOM RND
                    OnTime(x) = (MAX_ON - MIN_ON)* RND.HighByte / 255 + MIN_ON
                    OffTime(x)= (MAX_OFF - MIN_OFF)* RND.LowByte / 255 + MIN_OFF
        #ENDIF
        IF x != (LEDcount - 1) THEN Main
    Waiting: IF !CCPIF THEN Waiting
        CCPIF = 0
    GOTO Main
    SetFlashRates:
        If FlashMode = 0 Then
            PRI_HULL_LGHTS_ON_MS = 150
            PRI_HULL_LGHTS_OFF_MS = 50
        ElseIf FlashMode = 1 Then
            PRI_HULL_LGHTS_ON_MS = 50
            PRI_HULL_LGHTS_OFF_MS = 150
        Else
            PRI_HULL_LGHTS_ON_MS = 75
            PRI_HULL_LGHTS_OFF_MS = 83
        EndIf
        OnTime(8)  = PRI_HULL_LGHTS_ON_MS
        OffTime(8) = PRI_HULL_LGHTS_OFF_MS
    What am I doing wrong? In case anyone is wondering, I only want to randomize RA0-4 flash rates. Also, RA5 (MCLR) is input only so I had to make that a dummy output pin.
    Is there something special about RA7 because of Timer1?
    Not really ...
    nothing missing here ???
    Alain - not sure what you're referring to. Although I'm using 8 LEDs the 8th one is set up differently. You can see that farther done in the code with the GOSUB. The second last '2's are for the dummy MCLR pin. Rolls eyes.
    Darrel mentioned that the 'PORTB.0(x)' notation represents the offset from RB0, so maybe I'll try reverting to PortB but use 'PORTB.1(x)' to leave RB0 for the interrupt.
    May 2006
    Del Rio, TX, USA
    Ross,
    if you have declared:
    LEDcount CON 8
    and
    that will translates to an array indexed from 0 to 7, so
    Will not result in what you expect.
    If the array is 0-based then it should be this:
    OnTime(7) = PRI_HULL_LGHTS_ON_MS
    OffTime(7) = PRI_HULL_LGHTS_OFF_MS
    Oh, man - a real newbie mistake. Thanks Steve!
  1. Single button function
    Last Post: - 4th April 2020, 18:33
  2. How to blink 8 LEDs at different rates- concurrently?
    By rmteo in forum mel PIC BASIC Pro
    Last Post: - 26th April 2010, 23:47
  3. single sided PCB
    By schu4647 in forum General
    Last Post: - 10th December 2008, 18:22
  4. Can't Blink 2 LEDs
    By dfort in forum mel PIC BASIC
    Last Post: - 5th March 2008, 22:36
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 14:55
