Single PIC to Blink 5 LEDs Independently?
Results 1 to 40 of 69
    Default Re: Single PIC to Blink 5 LEDs Independently?
    I am not sure that I understood what you want to do. But looking on your schematic, I really do not think that is a good idea to have a pot drive the collector of the 2N2222 and then the transistor drive a load of 200mA. It is not good practice.
    If you need to control the power to your load, then a PWM controlling the base of the transistor is sure more appropriate.
    I got the design from another source. The idea was to provide a way to control the brightness of the LEDs without having to have the trim pot inside the model (the PCB will be in a base for easy access).
    The trim pots work great for all the other instances, just not the 5 steady-on LEDs. Also, I cannot use PWM in this code at all - it completely throws off the blinking algorithm created by Darrel.
  1. Single button function
    Last Post: - 4th April 2020, 18:33
  2. How to blink 8 LEDs at different rates- concurrently?
    By rmteo in forum mel PIC BASIC Pro
    Last Post: - 26th April 2010, 23:47
  3. single sided PCB
    By schu4647 in forum General
    Last Post: - 10th December 2008, 18:22
  4. Can't Blink 2 LEDs
    By dfort in forum mel PIC BASIC
    Last Post: - 5th March 2008, 22:36
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 14:55
