Single PIC to Blink 5 LEDs Independently?
Results 1 to 40 of 69
Threaded View
  1. #11
    Default Re: Single PIC to Blink 5 LEDs Independently?
    My god ... it's ... it's beautiful Just like a 1960's string of Christmas tree lights, the exact effect I'm after. I can't thank you enough, Darrel!
    One last query (I hope) - since I only need 5 output pins I would like to convert this to a 12F683. When I do, I get the 'ol "Redefinition of VAR" error pointing to this line:
    CCPR1      VAR WORD EXT : @CCPR1 = CCPR1L
    The whole code is here:
    '*  Author  : Ross Waddell                                      *
    '*  Notice  : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 10/27/2012                                        *
    '*  Notes   : PIC12F683                                                 *
    DEFINE BLINKYFREQ 100  ; 10mS periods
    ' Device Fuses
    ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
           __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOD_ON & _CP_OFF & _CPD_OFF
    OSCCON   = %01100000        ' 4MHz internal osc
    LEDcount    CON 5                  ; Number of LEDs on the PORT
    OnTimes     DATA  50,22,38,75,17   ; default periods for each Output
    OffTimes    DATA 150,45,38,95,117
    #DEFINE USE_RANDOM_SEQUENCE     ; comment for contiuous Sequence
    #IFDEF USE_RANDOM_SEQUENCE
        RND     VAR WORD : RND = 13864
        MIN_ON  CON 15                  ; Minimum random ON time
        MAX_ON  CON 115                 ; Maximum random ON time
        MIN_OFF CON 15                  ; Minimum random OFF time
        MAX_OFF CON 200                 ; Maximum random OFF time
        RandPeriod VAR WORD[LEDcount]
        RandPeriods DATA WORD 1000, WORD 1250, WORD 1500, WORD 1750, WORD 2000
    #ENDIF
    CCPR1val   CON EXT      : @CCPR1val = (OSC*1000000/4)/ BLINKYFREQ
    Timer1     VAR WORD EXT : @Timer1 = TMR1L
    CCPIF     VAR PIR1.5
    LoopLED    VAR BYTE[LEDcount]
    OnTime     VAR BYTE[LEDcount]
    OffTime    VAR BYTE[LEDcount]
    x          VAR BYTE
    ;----[Initialize]------------------------------------------------
    FOR x = 0 to (LEDcount - 1)         ; load the periods from EEPROM
        READ OnTimes+x, OnTime(x)
        READ OffTimes+x, OffTime(x)
            READ RandPeriods+(x<<1), WORD RandPeriod(x)
        #ENDIF
    NEXT X
    ;-- setup CCP1 and Start Timer1 --
    CCPR1   = CCPR1val     ; set compare value
    CCP1CON = %00001011    ; compare mode, special event
    Timer1  = 0            ; clear Timer1
    T1CON.0 = 1            ; start Timer1
    ANSEL  = 0
    TRISIO = 0             ; PORTC all OUTPUT
    ;----[Main Program Loop]----------------------------------------
        x = (x + 1) // LEDcount
        GPIO.0(x) = !!(LoopLED(x) < OnTime(x))
        LoopLED(x) = (LoopLED(x) + 1) // (OnTime(x) + OffTime(x))
            RandPeriod(x) = RandPeriod(x) - 1
            IF RandPeriod(x) = 0 THEN
                RANDOM RND
                OnTime(x) = (MAX_ON - MIN_ON)* RND.HighByte / 255 + MIN_ON
                OffTime(x)= (MAX_OFF - MIN_OFF)* RND.LowByte / 255 + MIN_OFF
        #ENDIF
        IF x != (LEDcount - 1) THEN Main
    Waiting: IF !CCPIF THEN Waiting
        CCPIF = 0
    GOTO Main
    Since there are no include files, my Google search didn't point to anything other than that. Is this too much to expect from a 12F?
  1. Single button function
    Last Post: - 4th April 2020, 19:33
  2. How to blink 8 LEDs at different rates- concurrently?
    By rmteo in forum mel PIC BASIC Pro
    Last Post: - 27th April 2010, 00:47
  3. single sided PCB
    By schu4647 in forum General
    Last Post: - 10th December 2008, 19:22
  4. Can't Blink 2 LEDs
    By dfort in forum mel PIC BASIC
    Last Post: - 5th March 2008, 23:36
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 15:55
