Single PIC to Blink 5 LEDs Independently?
Results 1 to 40 of 69
    Default Re: Single PIC to Blink 5 LEDs Independently?
    This may not be the right place to ask a technical question about the PIC 16F88 chip, but I thought I'd start here.
    I've got the prototype working and have been focusing on the schematic/board layout to finish this project (finally). After getting back some test PCBs for the blinking LEDs, I noticed that the 5 steady on LEDs connected to PORTA.0 via a 2N2222A transistor are not as bright as the other 5 blinking LEDs connected to PORTB.1-6 (note that PORTB.0 is needed for a button and that PORTB.7-8 are used for other blinking lights). I've looked over the datasheet for the PIC 16F88 but I'm a bit confused by the current limitations on page 163 (18.0 Electrical Characteristics). I had hoped that by using a 10k resistor between the 16F88 pins and the base of the 2N2222A that I could sink more current and hence drive more LEDs (PORTA.0 will ultimately need to drive 10 LEDs (5 per side of the model - total of 200mA for PORTA) while each of PORTB.1-6 will drive 2 LEDs (total of 200mA for PORTB). I see that it says 'Maximum current sunk by PORTA/B: 100mA' but I thought that a transistor (maybe a MOSFET?) would work.
    Am I dreaming here? Do I need to look for some other solution? I'd hate to move away from this single chip utilizing Darrel's most elegant code.
    PBP Code: Formation_Running_Engine_Lights_16F88_4Mhz_Ext_FINAL.txt
    Eagle Schematic: SE66_Main_Brd.pdf
    I am not sure that I understood what you want to do. But looking on your schematic, I really do not think that is a good idea to have a pot drive the collector of the 2N2222 and then the transistor drive a load of 200mA. It is not good practice.
    If you need to control the power to your load, then a PWM controlling the base of the transistor is sure more appropriate.
    I got the design from another source. The idea was to provide a way to control the brightness of the LEDs without having to have the trim pot inside the model (the PCB will be in a base for easy access).
    The trim pots work great for all the other instances, just not the 5 steady-on LEDs. Also, I cannot use PWM in this code at all - it completely throws off the blinking algorithm created by Darrel.
  1. Single button function
    Last Post: - 4th April 2020, 18:33
  2. How to blink 8 LEDs at different rates- concurrently?
    By rmteo in forum mel PIC BASIC Pro
    Last Post: - 26th April 2010, 23:47
  3. single sided PCB
    By schu4647 in forum General
    Last Post: - 10th December 2008, 18:22
  4. Can't Blink 2 LEDs
    By dfort in forum mel PIC BASIC
    Last Post: - 5th March 2008, 22:36
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 14:55
