compilation error
Results 1 to 12 of 12
    Default Re: compilation error
    Check the code here:
    http://www.picbasic.co.uk/forum/showthread.php?t=15960
    You are missing the PIC model after DEVICE.
    Jan 2012
    Thanks for the reply,
    And by the way interesting tutorial for me for further and later needs.
    But as for now I need this job urgently done for this IR project and I can't seem to get anywhere except with illegal opcode and found label after column 1 (DEVICE).
    You still do not have
    MCLRE
    Jan 2012
    MCLRE
    I did! Here it is once again!
    See if this works. I was not paying attention, you are using PBP 3 ?
    __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _LVP_OFF & _CP_OFF & _MCLRE_OFF
    This should work;
     __CONFIG _MCLRE_OFF & _INTRC_OSC_NOCLKOUT & _WDT_OFF & _LVP_OFF & _BODEN_OFF & _PWRTE_ON
    And disable case sensitivity in MPASM or make porta PORTA in the assembler part.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2012
    Lots of thanks to all contributions!
    Now I've got it.
    Special thanks to you Bruce, you just saved me a lot of effort.
    I was about to call Rentron and report this as I tried another code and had the same problem.
    Best regards to all.
