compilation error
Results 1 to 12 of 12
    Default Re: compilation error
    Why are you using that?
    Use MicroCode Studio that comes with PicBasicPro to edit the code and to invoke PicBasic to compile it.
    Jan 2012
    Thanks for the instant reply,
    But this is how I had learned to do the job for some time in the past before I started some C ...etc.
    please see attachment
    For the 628A...
    @ DEVICE MCLRE_OFF, INTRC_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF
    And the config type you are using is for PM. Is that set correctly in MCS?
    Check the code here:
    http://www.picbasic.co.uk/forum/showthread.php?t=15960
    You are missing the PIC model after DEVICE.
    Jan 2012
    Thanks for the reply,
    And by the way interesting tutorial for me for further and later needs.
    But as for now I need this job urgently done for this IR project and I can't seem to get anywhere except with illegal opcode and found label after column 1 (DEVICE).
    You still do not have
    MCLRE
    Jan 2012
    MCLRE
    I did! Here it is once again!
    Jan 2012
    For the 628A...
    thanks for the reply,
    I tried your suggestion but I keep getting an error
