compilation error
Results 1 to 12 of 12
    Default Re: compilation error
    For the 628A...
    @ DEVICE MCLRE_OFF, INTRC_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF
    And the config type you are using is for PM. Is that set correctly in MCS?
    Check the code here:
    http://www.picbasic.co.uk/forum/showthread.php?t=15960
    You are missing the PIC model after DEVICE.
    Jan 2012
    Thanks for the reply,
    And by the way interesting tutorial for me for further and later needs.
    But as for now I need this job urgently done for this IR project and I can't seem to get anywhere except with illegal opcode and found label after column 1 (DEVICE).
    You still do not have
    MCLRE
    Jan 2012
    MCLRE
    I did! Here it is once again!
    See if this works. I was not paying attention, you are using PBP 3 ?
    __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _LVP_OFF & _CP_OFF & _MCLRE_OFF
    This should work;
     __CONFIG _MCLRE_OFF & _INTRC_OSC_NOCLKOUT & _WDT_OFF & _LVP_OFF & _BODEN_OFF & _PWRTE_ON
    And disable case sensitivity in MPASM or make porta PORTA in the assembler part.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2012
    For the 628A...
    thanks for the reply,
    I tried your suggestion but I keep getting an error
