this is from the datasheet
Bit SPEN (RCSTA<7>) and bits TRISC<7:6> have to be
set in order to configure pins RC6/TX/CK and RC7/RX/DT
as the Universal Synchronous Asynchronous Receiver
Transmitter.
So maybe you need to set trisc.6=1 also?
Transmitter.
-Bert
OK, Just a Doh check for me, but I assume you DO have some kind of osc hooked up? xtal,resonator, something?
-Bert
Maybe the extra space between the T and the [ is messing things up?
If that is not the problem then double check the speed of your OSC. Receiving works, yes. But receiving is more tolerant than sending.. At least it seems that way. Are you using a crystal with caps or a resonator?Code:HSEROUT ["AT",10,13]
Unless my glasses are not thick enough, the hserin appears to be missing a variable to store value. Have you tried a single character? Maybe hserout will only send a string from an array ? Just thinking out loud . . .
Back to basics... do an HSEROUT loop, use a scope see if there's something happening on PIC pin... then on the TX of the MAX232. If so, check on the computer side.
