Simple code but strange result - 877A
Results 1 to 14 of 14
    Default Re: Simple code but strange result - 877A
    Do you have a schematic? What's RC.6 connected to?
    rc.6 ->Pin11 (MAX232) -> Pin14(MAX232) -> Modem Pin3 (Female RS232)
    ___________________
    WHY things get boring when they work just fine?
    I have NEVER used the USART to transmit so if I am wrong, . . . well here is my try . . .
    TXSTA.5 = 1 'which is transmit enable bit.
    Unhappy Re: Simple code but strange result - 877A
    Didn't Work
    ___________________
    Aug 2010
    Maryland, USA
    this is from the datasheet
    Bit SPEN (RCSTA<7>) and bits TRISC<7:6> have to be
    set in order to configure pins RC6/TX/CK and RC7/RX/DT
    as the Universal Synchronous Asynchronous Receiver
    Transmitter.
    So maybe you need to set trisc.6=1 also?
    -Bert
    Thanks for the reply. Tried the above - NO Luck
    ___________________
    Aug 2010
    Maryland, USA
    OK, Just a Doh check for me, but I assume you DO have some kind of osc hooked up? xtal,resonator, something?
    -Bert
    Maybe the extra space between the T and the [ is messing things up?
    HSEROUT  ["AT",10,13]
    If that is not the problem then double check the speed of your OSC. Receiving works, yes. But receiving is more tolerant than sending.. At least it seems that way. Are you using a crystal with caps or a resonator?
