Dimmer
Page 1 of 2 12 LastLast
Results 1 to 40 of 68
Thread: Dimmer
    Default Dimmer
    What would be the solution for following problem. I want to controll 2 opto SCR connected to RB1 RB2. I want one to increase light at the same time as the other Decrease light. The zero detection works perfect and also the delay for the ignition puls for scr1 but what about no 2.How do I solve it with Picbasic pro
    DELAY_1 = 8500 : us
    POS_FLNK:IF ZERODETECT = 0 Then POS_FLNK
    NEG_FLNK:IF ZERODETECT = 1 Then NEG_FLNK
    DELAY_1 = DELAY_1 - 1
    IF DELAY_1 < 7000 Then DELAY_1 = 7000
    PauseUs DELAY_1
    High out_1
    "High out_2"
    PauseUs 100
    "Low out_1"
    Low out_2
    GoTo POS_FLNK
    Since you want to basically complement the 2 outputs, the timing part is easy; assuming you are on 50 Hz, your circuit should see a zero crossing every 10 ms. Therefore, if the delay for one output is X, the other would be (10000-X) us.
    Now, the difficult part is that at times X will be less than (10000-X), and more than (10000-X) the other times.
    You'll need to therefore determine the sequence of servicing the 2 outputs.
    E.g., IF X < (10000-X) THEN PAUSEUS X, SWITCH ON TRIAC1, PAUSEUS (10000-X), SWITCH ON TRIAC2.
    IF X > (10000-X) THEN PAUSEUS (10000-X), SWITCH ON TRIAC1, PAUSEUS X, SWITCH ON TRIAC2.
    Take care of the situation when X = (10000-X) !
    Also allow for the time taken for the actual execution, or else you'll miss the subsequent zero crossing. This you could do by taling the half cycle width to be, say, 9000 us seconds instead of 10000.
    Hope this helps!
    Anand Dhuru
    What about the timing of the trigger pulse when they meet in the center "50%dutycyle". At one point the pic will be busy with 100us pulse for SCR1 and at the same time SCR2 should be triggerd. this might give some flicker. maybe the solution would be to make the dimfunction in lets say 10 or 20 steps and then take care of the overlap instead of a linear dimfuntion
    I've found that the trigger pulse can be as narrow as 5uS; therefore the flicker you refer to is imperceptible.
    Also, you could put in a line that caters specifically to this situation; e.g., if X = (1000-X) then High Out1 - Pauseus 5 - Low OUt1 - High Out2 - Pauseus 5 - Low Out2.
    BTW, I am using traics, not SCRs. Any particular reason you are using SCRs?
    Anand
    I am using a opto triac Sharp S216S01 so its not a SCR. have to check what the shortest triggpulse can be
    Thanks for you input
    Feb 2005
    Kolkata-India
    Default Which PIC are you using ?
    Hi there,
    Which PIC are you using ayway and how are you detecting the zero cross.
    It is also important if you are detecting every or alternate zero crosses.
    If you are using an interrupt based routine then do the following
    1. Play with Timer0 and reset it every zero cross. All turn off the outputs. Its best to do it in assembly.
    2. Thus your timer functions as a digital ramp generator now use to loop to detect if the timer has reached the desired value. In this way you do not have to care about the glitches.
    3. A 5us time might be not enough. It is best to keep the outputs latched till the next zero cross. This will also let you use low loads under the latching current of the SCR.
    Sougata
    I use a 16F84 8Mhz.Zero detection with an opto coupler after rectifyer 100Hz and then a schmittrigger to get the levels right. Have a <1ms puls around zero.
    It might be a good idea to make the pulse as long as it can be ,and bring it low just before zero. Sharp "s216s01" recomends 1mS min ,
    Assembly might be the best way of solving this ,since my goal is to control 5 outputs , I start with one then work my way up
    thanks
    New Zealand
    I use a resistor as zero detect, 1 meg from phase straight into the port, I then have a 470K resistor on the pin next door to it and swing the bias in an opposite direction to the mains ie:
    GPIO.5 is the output pin with the 470K on it - trigger is GPIO.4 which is connected upto the 1M which goes straight to phase. The triac is triggered by a BC327 and i trigger by turning pic from high impedance to low by changing from input to output.
    LowSide: 'look for trigger points and trigger triac
    IF trigger = 1 Then lowside 'wait for phase to go low
    GPIO.5 = 0 'weight input to sense zero crossing
    PauseUs dim 'wait for dim period
    Output triac 'fire triac
    triac = 0
    PauseUs 400
    Input triac
    HighSide:
    IF trigger = 0 Then HighSide
    GPIO.5 = 1
    PauseUs dim
    Output triac
    triac = 0
    PauseUs 400
    Input triac
    GoTo start
    Feb 2005
    Kolkata-India
    Default How would you like your outputs to be controlled
    Hi there,
    Having the opto-triac driven till the zero cross would take care of inductive loads also.
    Provide me with the following :
    1. How the outputs would be controlled? (Internal timer /push button etc)
    2. Your line frequency
    I would try to play with the interrupt part simulate it.
    Sougata
    What i wanted to do is a controller for some decorative lights. I want to make a pattern where light fade in / out.
    Powersupply = 50 hz 220V
    My first plan was to fade in/out between 2 limits on 1 channel "this works ok".
    then i wanted to try 2 channels to push the limit "a bit"
    Now I can see this extend to like 5 output creating a wave like motion.
    may be it will end up with a lot of assembly code and also lower the demands
    on "linear control" and go over to fixed steps and a data table
    could even parallell 5 pics to achive my goal this would be the last solution
    Feb 2005
    Kolkata-India
    Default I will be posting the code tomorrow.
    Understood. The only problem is that I don't have 16F84 ready. However it should work. Do you have a PIC18F452 ready? This is where I am most comfortable. I also have 16F676, 16F73, 16F619 handy. BTW you don't need five PICs.
    Sougata
    I have not done this but may be my idea could help.
    Using Interrupts, when there is pulse from zero-crossing detector, you could succeed in your house keeping, timing that is.
    Entering the ISR, the relevant registers would increment or decrement according the flags you have set in your main program. So there is accurate timing to fire every SCR even 5 or more since the ISR would be triggered every 10ms.
    Feb 2005
    Kolkata-India
    Talking I am working on a simplified version
    Hi Everybody,
    It is possible to trigger n numbers of SCRs within the 10ms(50Hz) time frame. My DMX Dimmer handles 48 of them. There I use a bubble sort algo and actually different interrupt sources. One for syncing the timer with ac, one for firing, listening to USART, fader read and so on. All this handled by two PICs 18F452 @ 40MHZ. The second one is mainly for the download and running of pattern or randomizing them.
    I am working on a simplified version using a PIC16F84A (Yes I found one) and trying to acheive a 100% PBP code using the On-Interrupt function. I have no idea about the latency till I get my code running tomorrow and checking on scope. Even the asm interrupt would be quite easy.
    You see with a clock frequency of 8MHz--> 2MHz(Fosc/4) / 128 (prescale) / 100 (reset every 10miliseconds), the timer0 would count 156 (50Hz) or 130(60Hz max). Compare this constantly in a loop with preset or increasing / decreasing values and fire the appropriate port.On interrupt
    1. Clear all outputs
    2. Reset Timer0
    3. Return
    Thats it. It will be done before the new cycle begins!!!!!!!!!2MIPS
    I am working on a two channel version and let you all guys out there juice it up.
    BTW most of the PICs have an inbuilt Schmidt Trigger on input ports so the interfacing is pretty easy. I use a couple of resistors a diode bridge and an optocoupler to derive the zero cross sync. It is accurate without any phase latency (as in the case of transformer based).Direct AC feed through high value resistor is also possible and practical but the circuit becomes live and is not recommended for experimenters.(I use it in my remote controlled fan/light dimmer to keep costs under control. It retails for about 18USD!!!!)
    The toughest part is possibly randomizing the paterns or using pschychedelic effect with beat detection within the scope of the chosen processor (clock code space, instruction set).
    We are having Diwali (the festival of lights) and a holiday to work with a fun project. The entire town is having myriads of lighting displays so why not doing one for the forum. Happy Diwaly to guys out there.
    It is midnight now and I can get my hands on the PIC only tomorrow when I get the lunch break. So till then....
    Bye!!
    Sougata
    Hello everybody
    What happend here , did the the project stall
    RGDS
    BG
    BMI
    Feb 2005
    Kolkata-India
    Default Sorry.
    Sorry guys,
    I could not keep up to my commitments. I lost a very near and dear friend. Give me a couple of days, I will get back with something working.
    A previous thread ==> http://www.picbasic.co.uk/forum/showthread.php?t=1026
    Schematic + code (Dimmer.zip) ==> http://www.melabs.com/resources/samples.htm#submitted
    Maybe not exactly what you need but should be enough to start
    Feb 2005
    Kolkata-India
    Unhappy Can somebody please test this thing?
    Sorry guys although I did a testing for a single channel version, I couldn't test the five channel one. I am posting the circuit and the code. I request the PIC gurus to have a look at the code and point the flaws. Please do read the notes.doc file for important information.
    Sougata
    Thank´s for the code Sougata. I will test it later. However I wrote some code myself and it works.I did not use Interupt´s.. There are some similaritys to what you wrote.
    But As i say I will try out your code later
    thanks
    BG
    BMI
    Reven's Avatar
    Reven Guest
    Can someone help me?
    I build the circuit from (Dimmer.zip) ==> http://www.melabs.com/resources/samples.htm#submitted,
    and I have this problem:
    If I press the increase button (<500ms) ,the lamp go on,full and if I press the decrease button, the lamp go off (normal).
    If I try to decrease the intensity from full on, or increase the intensity from off state, the lamp it fllash fast without decreasing/increasing brightness, until the lamp go on or off.
    On GP4 I have 50hz, and value at the pin GP2 while press the buttons, increment/decrement pulses by 500 uSec,until the maximum/minimum value, everything look ok.
    Any Help?
    Thanks!
    Have you adapted the program for the 50Hz line freq?
    Reven's Avatar
    Reven Guest
    Unhappy
    If you mean the maxdelay value, yes.
    But if you conect osciloscope and take a look at the pulses from the pic output and the 50Hz at the same time, you will see that the maxdelay value is only for the maximum brightness.
    Looks like a bad signal level to me...
    What is the voltage of your transformer?
    What are your R3 and R4 value?
    Try decrease R3 and post your results.
    Reven's Avatar
    Reven Guest
    Unhappy
    This is the osciloscope measures from the GP4 (AcLine input), and from GP2 (Output to TRIAC).
    I use tranformer 8Vac, R3=4k7 and R4=10k.
    Look the pictures from 0 to 4. Is from value off to on through 3 steps.
    But the lamp still flashing...
    Default This doesn't look right.....
    Reven,
    I've not used that circuit or code you are reffering to but by just looking at your waveforms it seems that the triac is triggered at the same phase angle in case 1, 2, 3 & 4.
    The triac only needs a short pulse on the gate and will then hold itself 'on' untill the AC-line crosses zero, at which point it will turn 'off'. That short pulse should be delayed a certain amount of time from the zero crossing.
    On your scope pics the triac seems to be triggered exactly 1div from the zero crossing in all cases except full on and full off.
    /Henrik Olsson.
    Wink Pulse position, not pulse length !!!
    Hi, reven
    Henrik is right ...
    Here, the pulse length is not the thing to be variable.
    but you must vary the time between zero voltage detection and triac gate firing ...
    Long time = weak light
    short time = full light
    remember once the triac is turned on it stays turned ON until current becomes null.
    Here, you had programmed a ... DC Dimmer !!!
    Reven's Avatar
    Reven Guest
    Thumbs up Pulse position, not pulse length...
    I think you have right...
    As Henrik says ,now the triac is triggered at the same phase angle in all cases.
    I must change my code to put the pulse position in a variable.
    Thanks all of you!
    I will inform you about my progress!
    BTW, take a look at the code,bacause I checked it many times and I could not find where the problem is.
    http://www.picbasic.co.uk/forum/atta...0&d=1103787743
    Thanks again,
    Reven
    Wink Got it !!!
    Hi, Reven
    Just understand what the interrupt routine does instead of should have done ...
    ' ACDetect
    ' Interrupt routine called by ACLine (GP4) pin state change
    disable
    ACDetect:
    if ACline==1 then ' Check for rising edge of AC signal
    if triacdelay > 0 then
    Triac=1 ' Activate TRIAC
    Alain's : ;;; No,No,No ... here we have to wait for ( Maxdelay - Triacdelay ) !!! THEN fire the Triac for, say, 20µs ... then let things quiet.
    if FullBright==0 then ' In case Brightness flag is not set
    pauseus triacdelay ' do the selected delay
    triac=0 ' Disable TRIAC
    triac=0
    INTCON.0=0 ' Clear GPIF (interrupt on GP4 change)
    resume
    enable
    *** This part of program smells to have been taken from a heather using burst mode dimming ...
    Sorry, Steve ... je t'aimais bien ( avec la musique de circonstance ... )
    mmm, sorry all. something should be wrong in what i posted. I used that program in various app and it worked... let me the time to return at home(Next week) and i'll compare the posted version and what i use...
    Many thousands of appologies.
    Can't wait to return home... use the following ACDetect routine instead.
    this should work.
    disable
    ACDetect:
    if ACline==1 then
        '    Rising edge of AC signal
    	if triacdelay then              ' A delay is set by user
    	    if FullBright==0 then       ' Full Brightness flag is not set
                pauseus maxdelay-triacdelay '    do the selected delay
                triac=1                     '    enable TRIAC
                else                        '
        	        triac=1                 ' Full Brightness flag is set
                                            '    enable triac
                endif                       '
            else                            '
        	    triac=0                     ' No Delay set by user... disable Triac
            endif                           '
        '    Falling edge of AC signal
            if fullbright==0 then triac=0   ' Disable the Triac on falling edge of
                                            ' Ac signal
    resume
    enable
    Yeah i know you can also use Pulsout and forget the Falling edge detection... as you wish. Both will work.
    Reven's Avatar
    Reven Guest
    Thumbs up Ok!
    First, I write something like this:
    disable
    ACDetect:
    if ACline=1 then ' Check for rising edge of AC signal
    pauseus 20
    Triac=0 ' Disable TRIAC
    resume
    enable
    and because I use half wave signal from the AC line on GP4, finaly something like this:
    disable
    ACDetect:
    pauseus 20
    'send a second pulse to triac,after 10ms, like the full wave
    pause 10
    pauseus 20
    resume
    enable
    Again, thanks all of you!
    Reven
    Sep 2006
    Florida, USA
    Default Problem with config fuse
    Hello - I am trying to compile the dimmer program and I am getting an error at the CONFIG fuse:
    @ __CONFIG _INTRC_OSC_CLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    It's giving me:
    Error ACLAMP~1.ASM 60: [235] opcode expected instead of '__config'
    Can anyone tell me what I am doing wrong?
    PBP 2.43 - PIC12F675
    Atom058
    You're using PM instead of MPASM to compile your code
    if you want to use PM, you must use the @ DEVICE directive instead.
    See the Faq about that. There's a whole thread about how to set config fuses in your code.
    Sep 2006
    Florida, USA
    Talking
    You're the MAN! Totally missed that one. Thanks!
    Sep 2006
    Florida, USA
    Default Schematic Critique
    Hello - I am trying to build the Dimmer Circuit as described and was wondering if someone could critique the attached circuit diagram. I have built this and do not seem to be able to get it to work and if it is not my design then it must be my code (both of which I obtained here). Any comments will be appreciated. I am using part numbers, schematic and code that are described here: http://www.melabs.com/resources/samples.htm#submitted
    Thanks! Atom058
    Sep 2006
    Florida, USA
    Default Oops!
    Here's the schematic....
    %%^%^&*&!#@$! it's my silly mistake. I will have to update the whole thing soon. Use...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1116&stc=1&d=116053407 7">
    You only have to move 1 wire...
    PCB mod... really easy
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1117&stc=1&d=116053452 8">
    SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY
    Sep 2006
    Florida, USA
    Mister-E - No harm done! Thanks for the quick response! I will give it a try tonight and we'll see what happens.
    Atom058
    Sep 2006
    Florida, USA
    Default PIC Issue
    I was trying to program a PIC12F675 to work with this dimmer design and I am obviously missing something. I copied the code from the Dimmer example and it was not working so I moved to a breadboard to do some testing. I can not even make an output on these PIC's go high! I know I am missing something but I can't imagine what it is! Here is the code - as simple as it is:
    @ DEVICE INTRC_OSC_NOCLKOUT & WDT_ON & MCLR_OFF & PWRT_ON & BOD_ON
    PAUSE 500
    CMCON=7 ' Disable analog comparator
    ANSEL=0 ' Disable analog converter
    TRISIO = %11111111
    TRISIO.0 = 0
    TRISIO.1 = 0
    TRISIO.2 = 0
    TRISIO.3 = 0
    TRISIO.4 = 0
    HIGH GPIO.0
    HIGH GPIO.1
    HIGH GPIO.2
    HIGH GPIO.3
    HIGH GPIO.4
    Start:
    GOTO Start
    Now, correct me if I am wrong, but I should be able to measure 5V at each of the 5 outputs above. I get nothing. I have tried several PICs and get the same results. I've written hundreds of programs for different PICs and this one has beaten me. I know the solution is unbelieveabley simple, but GEEZ!
    Jan 2006
    Istanbul
    Quote Originally Posted by Atom058
    @ DEVICE INTRC_OSC_NOCLKOUT & WDT_ON & MCLR_OFF & PWRT_ON & BOD_ON...
    Hi Atom,
    First thing, try these instead of the line above.
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    @ DEVICE pic12F675, WDT_ON
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, BOD_ON
    @ DEVICE pic12F675, CPD_OFF
    @ DEVICE pic12F675, PROTECT_OFF
    These should fix your problem.
    Second thing, GP3 is an input-only pin. Never goes high.
    Your @ device line is faulty...
    If you'e using PM to compile your code you must use something like
    @ device  pic12F675, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
    With MPASM
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    OUPS! SAYZER WHY YOU REPLYED AT THE SAME TIME
    i know this one is familiar to you
  1. PICDIM Lamp Dimmer for the PIC12C508 - PICREF-4
    By charudatt in forum General
    Last Post: - 2nd September 2015, 08:14
  2. Dimmer switch
    By iugmoh in forum Off Topic
    Last Post: - 20th March 2009, 17:02
  3. Ideas on ir-code for dimmer
    By tirithen in forum mel PIC BASIC Pro
    Last Post: - 14th February 2009, 00:22
  4. 50hz sync for light dimmer
    By tirithen in forum General
    Last Post: - 6th September 2008, 20:29
  5. Dimmer Circuit
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 15:37
