Dimmer
Results 1 to 40 of 68
Thread: Dimmer
    Sep 2006
    Florida, USA
    Default Problem with config fuse
    Hello - I am trying to compile the dimmer program and I am getting an error at the CONFIG fuse:
    @ __CONFIG _INTRC_OSC_CLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    It's giving me:
    Error ACLAMP~1.ASM 60: [235] opcode expected instead of '__config'
    Can anyone tell me what I am doing wrong?
    PBP 2.43 - PIC12F675
    Atom058
    You're using PM instead of MPASM to compile your code
    if you want to use PM, you must use the @ DEVICE directive instead.
    See the Faq about that. There's a whole thread about how to set config fuses in your code.
    Sep 2006
    Florida, USA
    Talking
    You're the MAN! Totally missed that one. Thanks!
    Sep 2006
    Florida, USA
    Default Schematic Critique
    Hello - I am trying to build the Dimmer Circuit as described and was wondering if someone could critique the attached circuit diagram. I have built this and do not seem to be able to get it to work and if it is not my design then it must be my code (both of which I obtained here). Any comments will be appreciated. I am using part numbers, schematic and code that are described here: http://www.melabs.com/resources/samples.htm#submitted
    Thanks! Atom058
    Sep 2006
    Florida, USA
    Default Oops!
    Here's the schematic....
    %%^%^&*&!#@$! it's my silly mistake. I will have to update the whole thing soon. Use...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1116&stc=1&d=116053407 7">
    You only have to move 1 wire...
    PCB mod... really easy
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1117&stc=1&d=116053452 8">
    SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY
    Sep 2006
    Florida, USA
    Mister-E - No harm done! Thanks for the quick response! I will give it a try tonight and we'll see what happens.
    Atom058
  1. PICDIM Lamp Dimmer for the PIC12C508 - PICREF-4
    By charudatt in forum General
    Last Post: - 2nd September 2015, 08:14
  2. Dimmer switch
    By iugmoh in forum Off Topic
    Last Post: - 20th March 2009, 17:02
  3. Ideas on ir-code for dimmer
    By tirithen in forum mel PIC BASIC Pro
    Last Post: - 14th February 2009, 00:22
  4. 50hz sync for light dimmer
    By tirithen in forum General
    Last Post: - 6th September 2008, 20:29
  5. Dimmer Circuit
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 15:37
