Here's the schematic....
%%^%^&*&!#@$! it's my silly mistake. I will have to update the whole thing soon. Use...
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1116&stc=1&d=116053407 7">
You only have to move 1 wire...
PCB mod... really easy
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1117&stc=1&d=116053452 8">
SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY SORRY
Mister-E - No harm done! Thanks for the quick response! I will give it a try tonight and we'll see what happens.
Atom058
I was trying to program a PIC12F675 to work with this dimmer design and I am obviously missing something. I copied the code from the Dimmer example and it was not working so I moved to a breadboard to do some testing. I can not even make an output on these PIC's go high! I know I am missing something but I can't imagine what it is! Here is the code - as simple as it is:
@ DEVICE INTRC_OSC_NOCLKOUT & WDT_ON & MCLR_OFF & PWRT_ON & BOD_ON
PAUSE 500
CMCON=7 ' Disable analog comparator
ANSEL=0 ' Disable analog converter
TRISIO = %11111111
TRISIO.0 = 0
TRISIO.1 = 0
TRISIO.2 = 0
TRISIO.3 = 0
TRISIO.4 = 0
HIGH GPIO.0
HIGH GPIO.1
HIGH GPIO.2
HIGH GPIO.3
HIGH GPIO.4
Start:
GOTO Start
Now, correct me if I am wrong, but I should be able to measure 5V at each of the 5 outputs above. I get nothing. I have tried several PICs and get the same results. I've written hundreds of programs for different PICs and this one has beaten me. I know the solution is unbelieveabley simple, but GEEZ!
Originally Posted by Atom058
Hi Atom,
First thing, try these instead of the line above.
These should fix your problem.Code:@ DEVICE pic12F675, INTRC_OSC_NOCLKOUT @ DEVICE pic12F675, WDT_ON @ DEVICE pic12F675, PWRT_ON @ DEVICE pic12F675, MCLR_OFF @ DEVICE pic12F675, BOD_ON @ DEVICE pic12F675, CPD_OFF @ DEVICE pic12F675, PROTECT_OFF
Second thing, GP3 is an input-only pin. Never goes high.
Your @ device line is faulty...
If you'e using PM to compile your code you must use something like
With MPASMCode:@ device pic12F675, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
OUPS! SAYZER WHY YOU REPLYED AT THE SAME TIMECode:@ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
i know this one is familiar to you![]()
Hi Steve,
As you well know, it took about a month for me to figure out that this line does not work:
@ device intrc_osc_noclkout, wdt_on, mclr_off, protect_off
It should be either like
or
like
Thanks guys! I knew I would be embarrased by the solution and I was right!
OK, Now I have made the circuit change and have made the switch changes. I get the 5V outputs on pins GPIO.0 and .1 which go low when I press the up or down buttons. I do not, however, get any output from GPIO.2 which is the triac trigger. My guess is that the problem lies in the ACDetect routine. I see in previous posts that there were many references to this routine and it went through several revisions. Can someone verify that I have the correct routine?
I have attached the code as a text file and the circuit design as a pdf. Would appreciate comments.
Thanks again! Atom058
