Dimmer
Results 1 to 40 of 68
Thread: Dimmer
    What about the timing of the trigger pulse when they meet in the center "50%dutycyle". At one point the pic will be busy with 100us pulse for SCR1 and at the same time SCR2 should be triggerd. this might give some flicker. maybe the solution would be to make the dimfunction in lets say 10 or 20 steps and then take care of the overlap instead of a linear dimfuntion
    I've found that the trigger pulse can be as narrow as 5uS; therefore the flicker you refer to is imperceptible.
    Also, you could put in a line that caters specifically to this situation; e.g., if X = (1000-X) then High Out1 - Pauseus 5 - Low OUt1 - High Out2 - Pauseus 5 - Low Out2.
    BTW, I am using traics, not SCRs. Any particular reason you are using SCRs?
    Anand
    I am using a opto triac Sharp S216S01 so its not a SCR. have to check what the shortest triggpulse can be
    Thanks for you input
    Feb 2005
    Kolkata-India
    Default Which PIC are you using ?
    Hi there,
    Which PIC are you using ayway and how are you detecting the zero cross.
    It is also important if you are detecting every or alternate zero crosses.
    If you are using an interrupt based routine then do the following
    1. Play with Timer0 and reset it every zero cross. All turn off the outputs. Its best to do it in assembly.
    2. Thus your timer functions as a digital ramp generator now use to loop to detect if the timer has reached the desired value. In this way you do not have to care about the glitches.
    3. A 5us time might be not enough. It is best to keep the outputs latched till the next zero cross. This will also let you use low loads under the latching current of the SCR.
    Sougata
    I use a 16F84 8Mhz.Zero detection with an opto coupler after rectifyer 100Hz and then a schmittrigger to get the levels right. Have a <1ms puls around zero.
    It might be a good idea to make the pulse as long as it can be ,and bring it low just before zero. Sharp "s216s01" recomends 1mS min ,
    Assembly might be the best way of solving this ,since my goal is to control 5 outputs , I start with one then work my way up
    thanks
    New Zealand
    I use a resistor as zero detect, 1 meg from phase straight into the port, I then have a 470K resistor on the pin next door to it and swing the bias in an opposite direction to the mains ie:
    GPIO.5 is the output pin with the 470K on it - trigger is GPIO.4 which is connected upto the 1M which goes straight to phase. The triac is triggered by a BC327 and i trigger by turning pic from high impedance to low by changing from input to output.
    LowSide: 'look for trigger points and trigger triac
    IF trigger = 1 Then lowside 'wait for phase to go low
    GPIO.5 = 0 'weight input to sense zero crossing
    PauseUs dim 'wait for dim period
    Output triac 'fire triac
    triac = 0
    PauseUs 400
    Input triac
    HighSide:
    IF trigger = 0 Then HighSide
    GPIO.5 = 1
    PauseUs dim
    Output triac
    triac = 0
    PauseUs 400
    Input triac
    GoTo start
    Feb 2005
    Kolkata-India
    Default How would you like your outputs to be controlled
    Hi there,
    Having the opto-triac driven till the zero cross would take care of inductive loads also.
    Provide me with the following :
    1. How the outputs would be controlled? (Internal timer /push button etc)
    2. Your line frequency
    I would try to play with the interrupt part simulate it.
    Sougata
  1. PICDIM Lamp Dimmer for the PIC12C508 - PICREF-4
    By charudatt in forum General
    Last Post: - 2nd September 2015, 07:14
  2. Dimmer switch
    By iugmoh in forum Off Topic
    Last Post: - 20th March 2009, 16:02
  3. Ideas on ir-code for dimmer
    By tirithen in forum mel PIC BASIC Pro
    Last Post: - 13th February 2009, 23:22
  4. 50hz sync for light dimmer
    By tirithen in forum General
    Last Post: - 6th September 2008, 19:29
  5. Dimmer Circuit
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 14:37
