How to make PWM to all the pins at the portB in same time on 16f628
Results 1 to 12 of 12
Threaded View
  1. #7
    errors with 16f628
    Fatal TEST.ASM 435 : [308] macro buffer overflow
    ;----[ MIBAM Setup ]--------------------------------------------------------
    BAM_COUNT CON 8                     ; How many BAM Pins are used?
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    BAM_DUTY  VAR BYTE[BAM_COUNT]
      LED1    VAR BAM_DUTY[0]           ; group them in an array for easy access
      LED2    VAR BAM_DUTY[1]           ; with FOR loops etc.
      LED3    VAR BAM_DUTY[2]
      LED4    VAR BAM_DUTY[3]
      LED5    VAR BAM_DUTY[4]
      LED6    VAR BAM_DUTY[5]
      LED7    VAR BAM_DUTY[6]
      LED8    VAR BAM_DUTY[7]
    BAM_LIST  macro                     ; Define PIN's to use for BAM
         BAM_PIN (PORTB,0, LED1)        ;   and the associated Duty variables
         BAM_PIN (PORTB,1, LED2)
         BAM_PIN (PORTB,2, LED3)
         BAM_PIN (PORTB,3, LED4)
         BAM_PIN (PORTB,4, LED5)
         BAM_PIN (PORTB,5, LED6)
         BAM_PIN (PORTB,6, LED7)
         BAM_PIN (PORTB,7, LED8)
      BAM_INIT  BAM_LIST                ; Initialize the Pins
    Speed       CON 6         ; Smaller = Faster
    TracerSpeed CON 15        ; Smaller = Faster Left/Right
    Brightness  CON 200       ; Tracers DutyCycle
    DrainSpeed  CON 30        ; Smaller = Shorter Trail
    Idx         VAR BYTE
    LoopCount   VAR BYTE
    NextLED     VAR BYTE
    TraceDIR    VAR BIT
      TraceDIR  = 0
      LoopCount = 0
      NextLED   = 0
        if LoopCount = TracerSpeed then             ; __[ Cylon/Kitt Scanner ]__
          LoopCount = 0
          BAM_DUTY(NextLED) = Brightness
          if TraceDIR then                          ; if scanning left
            NextLED = NextLED - 1
            if NextLED = 0 then TraceDIR = 0
          else                                      ; else scanning right
            NextLED = NextLED + 1
            if NextLED = BAM_COUNT-1 then TraceDIR = 1
        FOR Idx = 0 to BAM_COUNT - 1                ; Drain all dutycycles
           IF BAM_DUTY(Idx) > 0 then
               BAM_DUTY(Idx) = BAM_DUTY(Idx)*DrainSpeed/(DrainSpeed+1)
        NEXT Idx
        pause Speed
        LoopCount = LoopCount + 1
    GOTO Main
