http://picprojects.org.uk/projects/l...rpwm/index.htm
vivi this. In assembly language, I do not understand assembly,
Watch the clip 1.30 to 1.50 min. That I want to do but do not know how the PICBASIC PRO
There are a lot of effects in that video. This will do the "scanner" part: http://www.picbasic.co.uk/forum/showthread.php?t=10564&p=70256#post70256
http://www.scalerobotics.com
errors with 16f628
Fatal TEST.ASM 435 : [308] macro buffer overflow
Code:;----[ MIBAM Setup ]-------------------------------------------------------- BAM_COUNT CON 8 ; How many BAM Pins are used? INCLUDE "MIBAM.pbp" ; Mirror Image BAM module BAM_DUTY VAR BYTE[BAM_COUNT] LED1 VAR BAM_DUTY[0] ; group them in an array for easy access LED2 VAR BAM_DUTY[1] ; with FOR loops etc. LED3 VAR BAM_DUTY[2] LED4 VAR BAM_DUTY[3] LED5 VAR BAM_DUTY[4] LED6 VAR BAM_DUTY[5] LED7 VAR BAM_DUTY[6] LED8 VAR BAM_DUTY[7] ASM BAM_LIST macro ; Define PIN's to use for BAM BAM_PIN (PORTB,0, LED1) ; and the associated Duty variables BAM_PIN (PORTB,1, LED2) BAM_PIN (PORTB,2, LED3) BAM_PIN (PORTB,3, LED4) BAM_PIN (PORTB,4, LED5) BAM_PIN (PORTB,5, LED6) BAM_PIN (PORTB,6, LED7) BAM_PIN (PORTB,7, LED8) endm BAM_INIT BAM_LIST ; Initialize the Pins ENDASM Speed CON 6 ; Smaller = Faster TracerSpeed CON 15 ; Smaller = Faster Left/Right Brightness CON 200 ; Tracers DutyCycle DrainSpeed CON 30 ; Smaller = Shorter Trail Idx VAR BYTE LoopCount VAR BYTE NextLED VAR BYTE TraceDIR VAR BIT TraceDIR = 0 LoopCount = 0 NextLED = 0 Main: if LoopCount = TracerSpeed then ; __[ Cylon/Kitt Scanner ]__ LoopCount = 0 BAM_DUTY(NextLED) = Brightness if TraceDIR then ; if scanning left NextLED = NextLED - 1 if NextLED = 0 then TraceDIR = 0 else ; else scanning right NextLED = NextLED + 1 if NextLED = BAM_COUNT-1 then TraceDIR = 1 endif endif FOR Idx = 0 to BAM_COUNT - 1 ; Drain all dutycycles IF BAM_DUTY(Idx) > 0 then BAM_DUTY(Idx) = BAM_DUTY(Idx)*DrainSpeed/(DrainSpeed+1) ENDIF NEXT Idx pause Speed LoopCount = LoopCount + 1 GOTO Main
I did not get that error with your code, but I did need to add the stuff about wsave psave etc variables, which is explained in the mibam thread.
Code:;____[ For 12F/16F only - Interrupt Context save locations]_________________ wsave var byte $20 SYSTEM ' location for W if in bank0 ;wsave var byte $70 SYSTEM ' Alternate save location for W ' if using $70, comment out wsave1-3 ' --- IF any of these next three lines cause an error ?? ------------------- ' Comment them out to fix the problem ---- ' -- The chip being used determines which variables are needed ------------- wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1 wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2 'wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3 '---DO NOT change these----------------------------------------------------- ssave VAR BYTE BANK0 SYSTEM ' location for STATUS register psave VAR BYTE BANK0 SYSTEM ' location for PCLATH register
The macro buffer overflow happens when you use PM for the assembler.
Use MPASM instead.
Thanks guys
But how to high with 2.5 volts all pins at PirtB in the same time.
