How to make PWM to all the pins at the portB in same time on 16f628
Results 1 to 12 of 12
    Default How to make PWM to all the pins at the portB in same time on 16f628
    or is there another command: for example, eight LEDs connected portb 0,1,2,3,4,5,6,7 to work with 50% at the same time.
    At the same time to light and perish one by one with 100%.
    but never to perish under 50%.
    please help
    Jan 2006
    Istanbul
    Use a 7408.
    Connect one input of each "AND" to PWM output of F628A, all other inputs to your PORTB pins.
    Whenever and whichever of your PORTB pin is high, you will get the same PWM output.
    Bombay, India
    Smile
    Quote Originally Posted by sayzer View Post
    Use a 7408.
    CAN YOU tell me examples of how to do it
    Jan 2006
    Istanbul
    This picture is from WEB.
    http://picprojects.org.uk/projects/l...rpwm/index.htm
    vivi this. In assembly language, I do not understand assembly,
    Watch the clip 1.30 to 1.50 min. That I want to do but do not know how the PICBASIC PRO
    Quote Originally Posted by dejankengur View Post
    There are a lot of effects in that video. This will do the "scanner" part: http://www.picbasic.co.uk/forum/showthread.php?t=10564&p=70256#post70256
    http://www.scalerobotics.com
    errors with 16f628
    Fatal TEST.ASM 435 : [308] macro buffer overflow
    ;----[ MIBAM Setup ]--------------------------------------------------------
    BAM_COUNT CON 8                     ; How many BAM Pins are used?
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    BAM_DUTY  VAR BYTE[BAM_COUNT]
      LED1    VAR BAM_DUTY[0]           ; group them in an array for easy access
      LED2    VAR BAM_DUTY[1]           ; with FOR loops etc.
      LED3    VAR BAM_DUTY[2]
      LED4    VAR BAM_DUTY[3]
      LED5    VAR BAM_DUTY[4]
      LED6    VAR BAM_DUTY[5]
      LED7    VAR BAM_DUTY[6]
      LED8    VAR BAM_DUTY[7]
    BAM_LIST  macro                     ; Define PIN's to use for BAM
         BAM_PIN (PORTB,0, LED1)        ;   and the associated Duty variables
         BAM_PIN (PORTB,1, LED2)
         BAM_PIN (PORTB,2, LED3)
         BAM_PIN (PORTB,3, LED4)
         BAM_PIN (PORTB,4, LED5)
         BAM_PIN (PORTB,5, LED6)
         BAM_PIN (PORTB,6, LED7)
         BAM_PIN (PORTB,7, LED8)
      BAM_INIT  BAM_LIST                ; Initialize the Pins
    Speed       CON 6         ; Smaller = Faster
    TracerSpeed CON 15        ; Smaller = Faster Left/Right
    Brightness  CON 200       ; Tracers DutyCycle
    DrainSpeed  CON 30        ; Smaller = Shorter Trail
    Idx         VAR BYTE
    LoopCount   VAR BYTE
    NextLED     VAR BYTE
    TraceDIR    VAR BIT
      TraceDIR  = 0
      LoopCount = 0
      NextLED   = 0
        if LoopCount = TracerSpeed then             ; __[ Cylon/Kitt Scanner ]__
          LoopCount = 0
          BAM_DUTY(NextLED) = Brightness
          if TraceDIR then                          ; if scanning left
            NextLED = NextLED - 1
            if NextLED = 0 then TraceDIR = 0
          else                                      ; else scanning right
            NextLED = NextLED + 1
            if NextLED = BAM_COUNT-1 then TraceDIR = 1
        FOR Idx = 0 to BAM_COUNT - 1                ; Drain all dutycycles
           IF BAM_DUTY(Idx) > 0 then
               BAM_DUTY(Idx) = BAM_DUTY(Idx)*DrainSpeed/(DrainSpeed+1)
        NEXT Idx
        pause Speed
        LoopCount = LoopCount + 1
    GOTO Main
    errors with 16f628
    I did not get that error with your code, but I did need to add the stuff about wsave psave etc variables, which is explained in the mibam thread.
    ;____[ For 12F/16F only - Interrupt Context save locations]_________________
    wsave       var byte    $20     SYSTEM  ' location for W if in bank0
    ;wsave       var byte    $70     SYSTEM  ' Alternate save location for W
                                            ' if using $70, comment out wsave1-3
    ' --- IF any of these next three lines cause an error ?? -------------------
    ' -- The chip being used determines which variables are needed -------------
    wsave1      VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2      VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    'wsave3      VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    '---DO NOT change these-----------------------------------------------------
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    The macro buffer overflow happens when you use PM for the assembler.
    Use MPASM instead.
    Thanks guys
    But how to high with 2.5 volts all pins at PirtB in the same time.
    Help help
