PBP 2.60 upgrade and 18F4550
Results 1 to 11 of 11
    Several years ago, Microchip had erroneously called that bit _FCMEM_OFF_1H.
    I think mister-e pointed it out to me.
    You could ...
    1. Rename your config bit to that.
      The bit is in your c:\pbp\18F4550.INC file
    2. Correct the misspelled bit in Microchip's c:\program files\microchip\mpasm suite\P18F4550.inc file.
    3. Update MPLAB and it should go away.
      http://www.microchip.com/stellent/id...&part=SW007002
    If someone has a PBP version prior to 2.60 ...
    Use this one instead ... (MPLAB V8.15a)
    http://melabs.com/support/mplab_old_versions.htm
    Jul 2009
    Ohio, USA
    You could ...
    Ok...But rename it _FCMEM_OFF_1H. with an M or N?
